1974 Passengerside TCS switch
Discussion in '1974 Specific' started by Ricks72Z28, Apr 2, 2019.
  1. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,101
    25
    Jan 1, 2005
    Schererville,In.46375
    9F3E14AC-0A2B-477B-89FF-C9C13460FDCA.jpeg 49902894-3D04-493F-A55F-E9C25D6D5199.jpeg Well after years of searching with no luck... I was able to repair my original sensor and install it.
  2. ronzz572
    1,929
    52
    Feb 8, 2007
    imperial pa
    Nice work on it Rick, I will keep looking for a a replacement for you anyway.
  3. 74Z28GC3
    74Z28GC3 Veteran Member
    1,634
    31
    Sep 1, 2000
    North Pole, Alaska
    Very nice job repairing it Rick. What is the GM part number for this switch?
  4. Gary S
    21,922
    584
    That sensor isn't anything fancy. It is simply a temp controlled on/off switch. I expect you need to find one with similar switching temp and it would work. Later cars used lots of them for emissions controls mounted on the intakes and also on the thermostat housing. A little research should find one that would work right.
  5. Ricks72Z28
    1,101
    25
    Jan 1, 2005
    Gary, you are correct, but the difficulty is finding a single pole switch AC-93B.
  6. Jonesy
    Jonesy Veteran Member
    434
    Jun 7, 2008
    Minnesota
    Rick is right. My tab broke off just like yours did Rick. I still have it. I actually found a two spade switch and used the one side of the switch that was close to the spec of the original. Good luck finding a new one. This has to be the single most difficult part to find for a 1974 z28 with 4 speed.
