1975 Camaro Rear Axle
Discussion in 'Transmission & Driveline Topics' started by SPG, Oct 1, 2018.
  1. SPG
    SPG Bumblebee Builder
    326
    54
    Sep 1, 2018
    Sacramento
    Hello, I have a lot of questions but I'll just take it one step at a time. I got a 1975 camaro and will be putting a lt4 engine in it from a salvaged corvette....Since this motor has some serious power in it, should I replace the rear axle with something that's not older than I am? and if so what would you recommend I buy? I noticed a lot of people recommend moser but I honestly have no idea what I'm looking at...or if that's even a good deal.
  2. Gary S
    22,414
    754
    The rear axle in a 1975 Camaro is stronger than the axles used in the newer Camaros with the LT engines, so old alone isn't a problem. When it comes to GM rear axles, older means stronger.
  3. SPG
    326
    54
    Sep 1, 2018
    Sacramento
    Oh...fantastic! Always glad to hear I can save a few grand haha.
  4. BonzoHansen
    19,353
    724
    Jun 1, 2005
    Scott from Hamilton, NJ
    When the time comes I would simply rebuild the 8.5 you have now with quality parts, maybe step up to 30 spline axles.
    Lt4 like a late 90s vette motor? nice mill, but your current rear can take that no problem.
  5. SPG
    326
    54
    Sep 1, 2018
    Sacramento
    no, it's a lt4 from a 2015 z06
    I already have the engine in hand and works fine from what I've gathered (rear end collision, front is untouched)
  6. BonzoHansen
    19,353
    724
    Jun 1, 2005
    Nice!
  7. SPG
    326
    54
    Sep 1, 2018
    Sacramento
    With that powerful of an engine do you think I would still be fine? or no
    I'll upgrade to a 30 spline axle
  8. Peck
    Peck Veteran Member
    631
    159
    Mar 20, 2018
    Tacoma,WA
    Honestly you will probably still be fine, 30 spline axles never hurt anyone though.
    Is the differential open or positraction?
    Often times rear ends break not due to to much power but poor suspensions setup. Wheel hop and axle wrap will break things before power in my experience.
  9. SPG
    326
    54
    Sep 1, 2018
    Sacramento
    Limited slip (so I guess open)
    I want to put this level 2 suspension kit in it https://www.qa1.net/70-81-gm-fbody-handling-suspension-kits
    I don't plan on drifting or anything in this car....maybe autocross far down the future but I'm not a good enough driver for that.....and I honestly don't think I want to build the car for that.....yes I know the engine is way overkill, but I got it very cheap with the trans and computer, so who cares.
  10. big gear head
    big gear head Veteran Member
    6,175
    78
    Jul 30, 2001
    Central City, Ky.
    The 8.5 rear end in your Camaro is as strong as the rear end that was in the Vette that your engine came from. Most of the Camaors came with a standard differential, so upgrading to some type of limited slip differential is recommended. Also, the 30 spline axle upgrade should be done at the same time.
