1978 camaro turbine style aluminum rims AZ
Discussion in 'Swap Meet Section' started by AspenAuto, Aug 23, 2019.
Tags:
  1. AspenAuto
    AspenAuto Member
    35
    Aug 14, 2019
    Have a set of 4 matching 14inch aluminum rims that are coming off a 1978 camaro. Tried doing a little research and found a post on this site saying they came on 78 and 79s. Believe they call them turbine style.
    Have 2 of the center caps. Asking $350 for the set. If local pickup in arizona you can have the tires with it, if they have to be shipped I'll have to take them off and send just the rim. Shipping is probably in the $25-35 range per rim but I can find out exact with a zip code
