1978 Z-28 Speaker options.
Discussion in 'Car Audio, Electronics & Security' started by iraqivet, Jul 27, 2018.
  1. iraqivet
    iraqivet Veteran Member Lifetime Gold Member
    470
    24
    Nov 7, 2012
    Hobart, Indiana
    So on this 1978 Z-18 I just picked up, I removed the aftermarket speakers believing that where the left rear speaker was they cut it out since the 1978 GM Electrical diagram only shows an option for one speaker for the rear, listing it as the right rear and it would be installed by Body Company. It's actually stamped out like my other Camaro. So would I have to believe a RPO exists for dual rear speakers in a 1978 Camaro? Unfortunately even tough this is a California built car, the seats were not the original ones, hence no build sheet. I haven't dropped the gas tank yet but after the age of the vehicle I doubt that ones is even legible, let alone still there. So if any of you'78 owners have dual speakers in the rear, please let me know. If you know the RPO code, that would be great as well. I used speaker as a search word on the RPO web site, but no year is given for any RPO that lists speaker options. Thanks.
  2. Z28SSRS
    Z28SSRS Veteran Member
    153
    14
    May 2, 2009
    Nevada City, CA
    I am the original owner of a 1978 Z28 that I still own. Unfortunately it came from the factory with no radio. The dealership had a stereo shop install an AM/FM stereo radio with cassette tape player while I had lunch. I am only going by memory here, some 40 years ago, so bear with me. I know the car came from the factory with a windshield antenna (RPO U76). The Camaro White Book lists a rear speaker as an option (RPO U80). The 1978 Camaro sales brochure lists a rear seat auxiliary speaker as an option but not with stereo or tape systems. The only tape system listed as available is an 8 track. My car has one rear seat speaker on the left or driver's side rear shelf. So to the best of my knowledge no dual rear seat speakers were available from the factory. My car is a Van Nuys, California built car, and I found my build sheet on the underside of the driver's seat. So look there on yours. I hope this helps. Best of luck with your 1978 Z28. I still love mine after 40 years.
  3. Z28SSRS
    153
    14
    May 2, 2009
    Nevada City, CA
    In rereading your post I noticed you don't have the original seats anymore, but maybe the gas tank might have a build sheet on top hopefully.
    Thank you for your service.
  4. Zspoiler
    Zspoiler Veteran Member
    3,186
    247
    May 6, 2012
    Federal Way, Washington
    Do want dual rear speakers in the package you can always go aftermarket and or use a system from a 1979-81 Camaro of which had those options. I replaced the speakers in my 1979 Z-28 RS with Pioneers.But I used my original speaker covers. Maybe you could do something similar
  5. iraqivet
    470
    24
    Nov 7, 2012
    Hobart, Indiana
    I took off the fuel tank today and a good portion of the build sheet was legible. Unfortunately where any sound system would be listed is right where it sat on the gas tank rubber strip. So the black seat belts are original as I can read that. Black car, tan interior but with black seat belts. Must be a GM thing. Also had the optional adjustable driver's seat. Searching and deciphering a car's build and history make restoring a car much more enjoyable. Ah, the single rear speaker with the sound masked by a rear window defrost that sounds like a hair dryer.
    Anyone know what exactly B85 is? Is it side molding?
  6. 3504SPD
    3504SPD Veteran Member
    590
    Jan 30, 2011
    Central Valley California
    I looked at my build sheet. B85 says BELT MLDG
  7. 78TypeLTCamaro
    78TypeLTCamaro Veteran Member Gold Member
    485
    12
    Mar 2, 2001
    Waltham, MA. USA
    I have a 78 Type LT. It originally had a stereo with only one speaker in the rear. I am pretty sure they did not offer two speakers in rear and the reason is the rear defogger option was a fan in the rear deck.
  8. iraqivet
    470
    24
    Nov 7, 2012
    Hobart, Indiana
    That makes sense. Still interesting there are two speaker holes as well as the rear defroster holes punched out. Maybe a plan for it but it was cancelled. Looking at the 1978 Fischer Body and GM electrical diagrams, Fischer was responsible to add the rear speaker. No mention of the rear defrost on the GM schematic, but Fischer describes the system and shows diagrams in their Body manual. 78TypeLTCamaro, which side was your original single speaker in the rear on? Thanks.
  9. 78TypeLTCamaro
    485
    12
    Mar 2, 2001
    Waltham, MA. USA
    The stock rear speaker was on the driver's side. I now have 2 non stock speakers in the rear and recall the passengers side had a smaller hole for the fan which they had to enlarge both to allow the 6x9's to fit. Since this had A/C and originally from N.C. the original owner did not order the rear defog.
  10. iraqivet
    470
    24
    Nov 7, 2012
    Hobart, Indiana
    That's interesting you mention the driver's side. Z28SSRS also mentions the car he purchased new and still owns had no radio at first. He had the radio installed and the U80 RPO option installed. It was installed on the driver's side. The 1978 Camaro brochure shows the speaker also on the driver's side. In the RPO document, U80 is listed as a speaker, Right Rear. So it's Right Rear as you look at the front of the car. But the GM electrical manual lays it out as if it's installed on the passenger rear. If three vehicles are showing Driver's rear, That's where I install mine. I'm not making a concours correct Camaro, not enough funds for that. My 1980 and 1979 Z-28's have both been modified. I wanted to be able to make this build faster and go with an original look where possible.
