1979 Camaro rear differential
Discussion in 'Transmission & Driveline Topics' started by miastewie, Jun 19, 2019.
  1. miastewie
    miastewie New Member
    22
    Feb 28, 2013
    RIO RANCHO, NM
    Hello, I have a 1979 camaro with the stock 305 engine. I'm trying to find out what rear differential gear oil I need for this car and also if anybody knows if it has limited slip or not.
  2. Gary S
    22,298
    720
    The car could have been ordered either with or without positraction so you need to look it over and find out. The easiest way to find out is to remove the cover and drain the differential which you need to do anyway if you are changing the gear oil.
    We can't tell if we can't see it.
  3. Twisted_Metal
    26,875
    904
    If it’s a positraction (limited slip) rear you will also need the limited slip additive along with the gear lube.
    Pull the cover and post pics to be sure you use the right stuff.
    You can usually tell if it’s a posi rear by raising both rear wheels off the ground and spinning one wheel by hand. (Gear selector in neutral.)
    If they both turn the same direction, it’s a posi rear.
  4. miastewie
    22
    Feb 28, 2013
    RIO RANCHO, NM
    Thanks you guys for your fast replies, I'll have a picture up tomorrow and I'll also lift the back up and turn the wheels and let you know.
  5. RS1979
    3,697
    705
    Jun 18, 2013
    Memphis, TN
    Be sure and chock the front wheels. If you don't, the car can roll with the jack underneath it. Don't ask me how I know. LOL
  6. miastewie
    22
    Feb 28, 2013
    RIO RANCHO, NM
  7. Gary S
    22,298
    720
    Not a posi. Now, if you count the teeth on the ring and on the pinion, you can figure out your ratio. Or, simply turn the ring gear and look along the edge. If it is a factory ring and pinion, the numbers will be stamped on the ring gear.
  8. miastewie
    22
    Feb 28, 2013
    RIO RANCHO, NM
    I'm sorry for sounding like such an amateur, which one is the ring and which one is the pinion. And how do I turn the ring?
  9. Chevyforever
    Chevyforever Veteran Member
    482
    67
    Jan 4, 2011
    South Eastern Ontario
    big round gear is the ring gear, turn the driveshaft
  10. Bandit723
    Bandit723 Veteran Member
    3,145
    462
    Oct 1, 2016
    Waupaca WI
    looked at the picture kinda looks like the pinion gear is making contact with the carrier...
