1979 Z28 Stock Heads?
Discussion in 'Engine Topic' started by Red79z29, Nov 15, 2011.
  1. Red79z29
    Red79z29 Veteran Member
    199
    Nov 12, 2011
    Ohio
    Can anyone tell me what heads and camshaft came on a stock 1979 Z28 Camaro engine?
  2. Rumpity_z28
    Rumpity_z28 Veteran Member
    404
    Jul 27, 2004
    Hope B.C.
    im not sure about the cam but heads on mine were 882's
  3. 1981zapper
    1981zapper Veteran Member
    Head Cating #: 333882 1.94/1.5" Valves, 75.47cc
    Cam specs: Hydraulic, Lift: .390/.410 (intake/exhaust), Duration: 310/320
  4. mrvedit
    mrvedit Veteran Member
    1,346
    Jun 12, 2009
    Ann Arbor, MI
    Interesting how little the lift is; no wonder it was rated at only 175(?) HP.
    But please correct the duration, I would like to know what it was at .050. :)
  5. 1981zapper
    Duration @ .050 195/202
  6. Red79z29
    199
    Nov 12, 2011
    Ohio
    Yeah you're right with the 175 HP (I am surprised with so little lift also), and yes can you please tell the duration at .050?
  7. Red79z29
    199
    Nov 12, 2011
    Ohio
    Sorry didn't see you posted already. :)
  8. mildthing
    mildthing Veteran Member
    217
    Nov 17, 2011
    Benson, Utah
    The cam was the 3896929, 112 lobe sep, ground 4 degrees advanced. The other specs given match the old TRW specs. '79 should be the guaranteed-to-crack # '624 heads, which typically get replaced by the '882s. Should be 1.94"/1.50" valves.
  9. Hulk_smash
    Hulk_smash New Member
    21
    Feb 14, 2016
    Sanford FL
    I would like to install a better cam just don't know which one but need a little help to narrow it down
  10. tom3
    tom3 Veteran Member
    10,729
    61
    Aug 1, 1999
    ohio
    Best deal on that engine would be a set of Vortec heads with some 1.6 ratio rockers to improve lift on the peanut cam, set of headers. Feel the difference in the seat of your pants.
