1987 IROC-Z's, IROC-Z or Z28 on the rocker panels
Discussion in 'Body Restoration' started by mgd1790, Jul 12, 2018.
  1. mgd1790
    mgd1790 Veteran Member
    982
    26
    Nov 25, 2003
    Suburban Chicago
    I've been looking at '87 IROC's and I've seen some that seem to have Z28 on the rocker panels and some that have IROC-Z. Is this a late production year change as I seem to have seen legit IROC's with Z28 and some with IROC-Z. All the '88's I've seen say IROC-Z.
    Appreciate any insight.
  2. BonzoHansen
    19,442
    798
    Jun 1, 2005
    Scott from Hamilton, NJ
    Iirc 87 could be a z or an iroc. not true all years.
    Thirdgen.org has good write ups off the home page
  3. mgd1790
    982
    26
    Nov 25, 2003
    Suburban Chicago
    So there is Z28 Iroc and a pure Iroc-Z?
  4. BonzoHansen
    19,442
    798
    Jun 1, 2005
    I think in 87 there was a z28 and an iroc-z. check third gen
  5. bodymanbill
    bodymanbill Veteran Member
    1,309
    675
    Feb 1, 2007
    South Park Pa
    My 87 IROC just says Z28 on the rockers
  6. ggtsvnv
    ggtsvnv Veteran Member
    1,185
    54
    Jun 20, 2002
    Reno NV,
    If I remember correct; 85 through 87 when both the z28 and irocz were available they just said z28 on the rockers. And Iroc's had the irocz door stickers. Starting in 88 when they went to just irocz that was when they added the irocz rocker emblems.
  7. JT71SS
    JT71SS Veteran Member
    500
    Jan 26, 2003
    McConnelsville Ohio USA
    85-87 Will say Z28 on the rocker panel on the IROCs . 88-90 will say IROC-Z on the rocker.
  8. JT71SS
    500
    Jan 26, 2003
    Also 85-87 you could get a z28 and a Iroc-z. The z28s had silver ground effects where the Irocs was body color with 16 inch wheels. In 88 the Z28 was dropped you could just the Iroc then.
  9. mgd1790
    982
    26
    Nov 25, 2003
    Suburban Chicago
    Interesting. I was looking at an 89 iroc’s RPO’s and it has engine 350 this and that (L98, B2-whatever its called) and Z28 there too
  10. ggtsvnv
    1,185
    54
    Jun 20, 2002
    Reno NV,
    Remember it's a 30 year old car hard to say how much could have been or has been changed. I don't think z28 emblem would be correct for an 89 being the last year of z28 was 87 (until 91 anyway). The best way to check if it's an iroc is the sticker in the console. Also only iroc's got a 350 (5.7) engine so if the Vin decodes as a 350 then it has to be an iroc. Also if it decodes as a TPI it has to be an iroc even if it's a 305. No plain Camaro with TPI. The engine code in the Vin is the key for you to know for sure. Remember irocz, was short for international race of Champions z28. On the sticker in the glove box it should have z28 and both b4c IIRC.
