1991 Chevy Truck 5 speed experts
Discussion in 'Transmission & Driveline Topics' started by f-body, Aug 20, 2007.
  1. f-body
    f-body Veteran Member
    1,674
    Feb 1, 2000
    Dallas
    So I have this 1991 shortbed 1/2 ton 1500 series 4.3 V6 and 5 speed truck. Well the trans is making noise. And I know eventually its gonna need a rebuild. IS there a difference between the S10 5 speeds, the 1/2 ton 5 speeds or the truck 5 speeds that came installed behind V8 or V6's. I have the Getrag 5 speed or 85MM trans according to the Chiltons book.
    Can I easily swap in another type of 5 speed?
    What kind of limits do these trannys have as far as towing?
    What other year truck 5 speeds will bolt right in with little or no modifications?
    Any of you transmission experts please help out.
  2. jakeshoe
    8,856
    Dec 8, 2000
    Republic of Texas
    That is the NV3500 IIRC.
    One piece case.
    Don't tow in 5th, it kills the input cluster.
    Some guys use a different fluid in it, thicker I believe to help the gear clash.
    Different than the S10's, same on all the full size trucks, 4.3 or 5.7 AFAIK.
  3. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    If you are looking to pick up a different transmission you will want to check prices before you make too many plans. The NV3500 is EXPENSIVE!
  4. f-body
    1,674
    Feb 1, 2000
    Dallas
    hey Jakeshoe
    (Wow a member form the original board)
    So how much should it cost for a rebuild? I know you do autos do you rebuild manuals also?
    What other 5 speeds will bolt right in?
    I really do not tow very often but want to be able to.
    What should I look for if I go the salvage yard route?
  5. jakeshoe
    8,856
    Dec 8, 2000
    Republic of Texas
    I don't really rebuild them. I don't have the spare parts if I need something and it's a hassle.
    You can call around and get pricing on them, but look for one with a warranty.
    I can check with my suppliers and see what a good one costs or a reman'd unit.
    I don't know of anything else that will easily fit. You're stuck with that unless you want to do some custom retro-fitting.
    You can tow with it, just not in 5th, you need to get back into 4th that way you aren't transmitting the OD load onto the input cluster, the mainshaft will be locked to the input in 4th (direct) and no load on the countershaft.
  6. jakeshoe
    8,856
    Dec 8, 2000
    Republic of Texas
    I can buy them rebuilt for $850 plus $200 core.
  7. f-body
    1,674
    Feb 1, 2000
    Dallas
    Jakeshoe
    What about a 5 speed with the granny gear like in a 3/4 ton or HD model? Its not much of a half ton tranny but would they hold up better. Will it fit in the half ton with a different crossmember or will big mids be required. I could always through a Richmond trans in it. OR use the long tail shaft TH350 auto in the camaro and get the richmond for the camaro. HMMMMM.
    CHEVROLET TRUCK 3500 2500 TRANSMISSION NV4500 5 SPEED
    http://cgi.ebay.com/ebaymotors/CHEV...ryZ33733QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    or this one
    Chevy/GMC 2500-3500 Transmission gas, diesel,2x4,4x4
    http://cgi.ebay.com/ebaymotors/Chev...ryZ33733QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  8. jakeshoe
    8,856
    Dec 8, 2000
    Republic of Texas
    I don't know how difficult it would be. I've never done that conversion.
    It may require a different floorpan or trans tunnel, probably would require driveshaft and crossmember mods, and definitely will require you to find a bellhousing and the associated hyd clutch parts.
    Stock trans has a one piece case, so the bell is part of the trans.
  9. f-body
    1,674
    Feb 1, 2000
    Dallas
    Jakeshoe
    What years had the same 5 speed trans as my 1991? How new a truck can I uses a similiar 5 speed from? I was considering using a 5 speed from a newer truck if its a bolt in or very easy to install. I know the LS engines are different and use a different bolt pattern.
    I know I cannot use the 5 speed from a truck with the LS series engine like the 5.3 but what year did they start using the LS in the truck? I know it was 1998 for the camaro and firebird and 1997 in the corvette.
  10. jakeshoe
    8,856
    Dec 8, 2000
    Republic of Texas
    1999 was the last year for a conventional SBC in the trucks, but keep in mind there may be speedometer differences between a 91 and 99.
    GM did a couple of different iterations of speedos in the 90s. Cable driven pretty much went away in the very late 80s, but they had a couple of different reluctor ring counts inside the trans.
