1993 350 5.7 truck engine CORE Question
Discussion in 'Troubleshooting & Diagnosis' started by Lou6t4gto, Nov 14, 2019.
  1. Lou6t4gto
    Lou6t4gto Veteran Member
    340
    16
    Aug 18, 2010
    Ocala, Fla
    I've been tearing down engines for 50 years (all kinds) maybe my memory is getting bad but, this engine #14093638,(dished pistons, 193 heads, Flat tappet hydraulic, 1 piece rear main). the "LIFTERS" are about 3/8" down in the lifter bore, they come up to almost level when the Valves OPEN. Aren't they "normally" at the Top of the bore and come Out of the bore when the valve is open in an older sbc ??? OR are these Blocks different ? (use different push rods ?) (small base circle cam)? I know most engines after 1987 had roller lifters. I want to use it with different pistons, aluminum heads and an old style 30/30 flat tappet "solid" lifter cam.
    thanks for any help
  2. Lou6t4gto
    340
    16
    Aug 18, 2010
    Ocala, Fla
    No One has ever seen this ????
  3. badazz81z28
    16,980
    520
    Las Vegas, NV
    I don’t recall the lifters sticking out of the bore too much, just enough to be above the dog bone
  4. Lou6t4gto
    340
    16
    Aug 18, 2010
    Ocala, Fla
    AND this 350/5.7 has a "Externally Weighted flex plate " ( engine block 149939638 "date code"- Aug 15 1991) !? I thought only sb 400s were "externally" balanced ?
  5. Lou6t4gto
    340
    16
    Aug 18, 2010
    Ocala, Fla
    **this one, the TOP of lifters is 3/8" Down In The Hole, and only come up to the top when the valve is fully OPEN !
  6. bourbon_scotch
    2,402
    143
    Jan 10, 2003
    USA
    Manufacturer: Chevrolet
    Category: Engine Blocks
    Type: Small Block V8
    Date: 1987-1995
    Notes: 350, 2 bolt or 4 bolt, roller or flat tappet cam, 1-piece rear seal
    http://www.castingnumbers.info/site/search/14093638
    22 350 5.7 89-93 7 V8 OHV, RWD, TBI, roller lifters, center bolt valve covers, high swirl intake ports, right hand dipstick 14093638 14011148 10054727 14088526 14088535 14102193 14102191 10110810
    23 350 5.7 87-92 8 V8 OHV, RWD, PFI/TBI, roller lifters, center bolt valve covers, high swirl intake ports 14093638 14088526 14011148 14088526 14088535 14102193 14102191 10110810
    24 350 5.7 87-92 8 V8 OHV,RWD, PFI/TBI, roller lifters, center bolt valve covers, low swirl intake ports 14093638 14011148 14088526 14088535 14101083 14096217
    http://www.jimsperformance.com/blocks.html
    then check this out
    http://nastyz28.com/threads/1992-truck-350-roller-block-or-not.165632/
  7. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,698
    17
    Jul 31, 2001
    Ft. Lauderdale, FL
    The change in the lifter bore height was made in 1986. The block should also have the raised bosses that are not drilled for the roller lifter retainer plate.
    Many of the truck engines after 1986 were still not roller tappet engines. Regular hyd flat tappets and normal length push rods go in them
  8. Lou6t4gto
    340
    16
    Aug 18, 2010
    Ocala, Fla
    thats what it is, No Rollers. just seems strange. if GM was making roller motors after 87, WHY put in the boss for the roller cage and not tap it ? simpler to make them ALL the same "Block". Never understood why GM did alot of things other than squeezing pennies.
