1998 Silverado K-1500 Fuel Pump
Discussion in 'Troubleshooting & Diagnosis' started by GREGS396, Nov 24, 2012.
  1. GREGS396
    GREGS396 Veteran Member
    2,398
    8
    Oct 16, 1999
    allentown pa
    After 14 years and 114k miles, the fuel pump on my truck went the other day. Given that they are an issue after this amount of time, I was kind of waiting for it to give out.
    My question here is if I should go with a dealer OEM part, which will run me about $350, or if I should just get a Bosch one from Advance Auto, which will run me $280 with a 20% discount they are running...
  2. Knuckle Dragger
    14,701
    1,267
    Nov 2, 2002
    Waddell AZ
    O.E part is made by Aritex
  3. KEVS79
    KEVS79 Veteran Member
    2,465
    Mar 3, 2008
    GLADSTONE, MO
  4. krabben1
    8,159
    44
    May 16, 2007
    ( . Y . )Delco
    I put a parts store one in mine.To be honest,I have more faith in an aftermarket brand name than a gm one,sad to say it.
  5. Mike N
    2,739
    521
    Jan 13, 2002
    Spencerport, NY.
    I put a Delphi pump in my Wife's 98 Z/71. Factory one lasted 186,000 miles. Was still working when I changed it, but it was whining so loud I'm sure the neighbors could hear her coming down the road. Only a matter of time before it crapped out.
    I wouldn't put a Bosch anything on any car I own. I've never had any luck with anything that ever had Bosch printed on the package.
  6. bigblockbird75
    bigblockbird75 Veteran Member
    197
    Jun 5, 2012
    Binghamton, NY
    I'd go with delphi if its an option. Bosch is good with some things, other things are junk. I've never used one of their fuel pumps. I'd stay away from airtex if possible(I'm pretty sure airtex didn't make the stock ones). I've never got more than a year or two out of them.
  7. gpintauro
    gpintauro Veteran Member
    184
    Jun 4, 2012
    inman,sc
    if you're mechanically inclined and replacing the pump yourself, you can buy just the fuel pump and replace it. you do not need to buy the whole fuel pump module. The pump itself is less than $100
  8. stroked383
    stroked383 Veteran Member Lifetime Gold Member
    764
    Jul 18, 2011
    Saugerties, NY
    I wouldn't use the Airtex crap. I have replaced more Airtex pumps than OEM
  9. Mike N
    2,739
    521
    Jan 13, 2002
    Spencerport, NY.
    I've tried that on a few GM's and ime it's more of a pita than it's worth.
  10. KansasTwister
    KansasTwister Veteran Member Lifetime Gold Member
    1,389
    Oct 7, 2006
    Lawrence, ks
    On my systems at work (oreillys) delpi is listed as the oem part, not the airtex. and we switching airtex to precision, not that they are any different quality than airtex, same prices at least.
