1999 Dodge Ram Random Cylinder Misfire
Discussion in 'The BS Topic' started by TDPalmer, Oct 31, 2012.
  1. TDPalmer
    TDPalmer Veteran Member Lifetime Gold Member
    823
    Apr 25, 2011
    Cave City, Arkansas
    On my '99 dodge ram my check engine light has been coming on recently. When I read it with a code I get a "Random Cylinder Misfire" or a "Cylinder 1 Misfire". I've replaced the spark plugs, wires, cap and rotor twice myself, and the last time I had a shop do it. The light will stay off for about 3 weeks after each one. Something else that happens is sometimes when I go to start my truck it will die as soon as it cranks over the first time. But it will always start the second time.
    I'm wondering if the computer or something could be going bad. The truck was originally a 318 truck but I swapped a new mopar 360 crate engine into it.
    Anyone ever have this problem?
  2. fbody_mike
    fbody_mike Veteran Member
    972
    Mar 24, 2009
    San Gabriel Valley, California
    I have had a similar problem, but not on a Dodge, it was on my chevy 3.1L. Codes would come up random misfire, or cylinder 4 misfire. So like yourself I changed the plugs and wires. Problem was intermittent, and would go away after the "tune-up". After a few weeks sometimes, months, the problem would come back. New plugs, the problem would seem to go away. I finally threw parts at it until it was solved. It turned out that the ignition module was bad. If I were you I would try to find a similar truck in a wrecking yard and pull all the ignition stuff to try to do the shotgun approach to troubleshooting on the cheap side.
  3. Camaro75LT
    Camaro75LT Masshole Staff Member Lifetime Gold Member
    6,651
    89
    May 17, 2001
    Boston-ish
    Checked for vacuum leaks?
  4. harbone66
    3,499
    286
    Feb 15, 2011
    Central Illinois
    When you did the swap did you change the flywheel to a 360 unit? I seem to remember one of my customers doing the same engine swap in the past and had the same problem.
  5. TDPalmer
    823
    Apr 25, 2011
    Cave City, Arkansas
    I tried to check for vacuum leaks using a unlit torch and the engine did not speed up, the engine runs great and doesn't lag or bog down at all.
    The Chrysler place that did the swap told me I needed a 360 torque converter or a flywheel with weights on it. I went the torque converter route. To my knowledge they did not reflash the computer
    I'll try to check into the ignition control module also.
  6. gramps
    gramps Veteran Member
    912
    303
    Jul 5, 2009
    mankato, mn
    Should not have to run anything different computer wise. Converter or weighted flex plate yes.
    Probably should have it on a scan tool (not cheapie code reader) and see what and when it's misfiring. Could be bad ignition module, bad distributor, or other sensor like crank position which are common on those. Is it a rich misfire or lean misfire? Could also point to injectors either sticking open or shut, or as often as it is mentioned lol an O2 sensor reading poorly causing the computer to under fuel it. Temp sensor can cause same thing.
  7. david.rosol
    david.rosol Veteran Member
    1,119
    8
    Jul 2, 2009
    Southern Maryland
    Had the same issue you are having a few years ago on my 01 Ram w/360 motor. I did all the same things you did but the problem kept coming back. Eventually took it to the dealership for them to run their diagnostics on and everything and to make a long story short, it turned out to be a sticking valve due to a recessed valve seat.and eventually ended up having to replace the heads.
  8. Prototype4342
    Prototype4342 Veteran Member
    1,474
    Sep 10, 2010
    Las Cruces, NM
    inb4 Aceshigh
    Bring this up on dodgetalk.com, good guys.
  9. nicks78camaro
    nicks78camaro Veteran Member
    862
    Apr 3, 2010
    Pittsburgh
    Just had something like this in the shop, always was hard to start when cold, but once it was started it ran fantastically.
    Trned out to be the ASD (automatic shutdown relay) connection in the fusebox was bad. When that connection is bad, the communication between the oxygen sensors, the fuel injectors, and ignition coils is interrupted. Swapped in a new relay with dielectric grease on it, fixed the problem.
    Vehicle was a 2001 Ram 1500 360ci auto 4x4
  10. TDPalmer
    823
    Apr 25, 2011
    Cave City, Arkansas
    Was the relay corroded or anything that led you to believe its bad? I checked my ASD relay and the prongs were still shiny on it.
