1LE fit behind 15inch rally
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by vince72, Oct 16, 2019.
  1. vince72
    vince72 Veteran Member
    960
    Jul 19, 2003
    orange county california
    Hey Guys
    Wondering if anyone has luck with this brake and wheel combo?
    I’d like to know before I buy all the pieces
    Thanks
    Vince
  2. Lowend
    15,013
    481
    Mar 25, 1999
    San Jose, CA, USA
    This generally will not fit with a 15" wheel without some grinding (at best).
  3. vince72
    960
    Jul 19, 2003
    The grinding would be to the calipers?
  4. Jeep43
    Jeep43 Veteran Member
    1,301
    48
    Mar 30, 1999
    Connecticut
    I have read that 5 spoke Z28 wheels will clear the B-body spindle 1LE swap. I bought everything to do it based on that but haven't had time to perform the swap.
  5. Lowend
    15,013
    481
    Mar 25, 1999
    San Jose, CA, USA
    On my car - the factory 5-spoke rallys would not clear the 1LE setup. I believe the late 70's Corvette 15x8" slot mags will
    In general - almost all 15" tires suck now, if you want to improve braking getting a modern set of wheels/tires will make more difference than anything
  6. BonzoHansen
    19,441
    797
    Jun 1, 2005
    Scott from Hamilton, NJ
    I ran 15" z28 steels no problem. No alterations at all
    Aluminum 15" N90s do not fit.
  7. badazz81z28
    16,946
    506
    Las Vegas, NV
    I agree, if you feel you need a brake upgrade, tires are probably on the list too. In fact, the 1LE not fitting in my turbines is what led to my 17” wheels. Then I just opted for the 13” C5
  8. 79T/Aman
    2,532
    175
    Oct 7, 2004
    Dickson TN.
    with the iron caliper they should fit most steel 15" wheel, they fit my Pontiac WS6 15x8 aluminum wheels, I have no experience with the Camaro but Bonzo said they didn't fit with the N90, what wheel are you trying to use?
  9. Twisted_Metal
    27,086
    1,005
    Another factor is balancing weights.
    If the wheels are balanced with stick-on weights inside the rim rather than at the inner and outer edges... They will limit caliper clearance.
    Aluminum wheel castings are a bit thicker than steel wheels and the internal diameter (where the calipers sit) will be smaller.
    I had to remove wheel weights, hammer them flatter and reattach them in order to clear factory 14" N90 wheels with stock calipers.
  10. vince72
    960
    Jul 19, 2003
    I am trying to run 15 by 7 inch rally wheel with a wilwood caliper
