1LE spindles
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 79T/Aman, Aug 27, 2019.
  1. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,452
    132
    Oct 7, 2004
    Dickson TN.
    Another key point, I think my title may confuse people into thinking and questioning why the 1LE brakes? it's not just made for that
    There is currently nothing available on the market that compare, the other two styles available are
    *Drop spindles, too many negatives, they cause interference between the outer tie rod and the rim (unless you run shallow back space, fine for drag cars) increased scrub radius, lowers roll center, no steering improvements.
    * C5 hub style, expensive hubs, no steering stops, no steering improvements.
    -This is a NEW spindle with STEERING improvements first and foremost.
    -Making them to accept the GM 12" rotor was made to fit circle track racing rules as well as providing an easy brake upgrade for those on a budget.
    -these spindles are fully compatible with aftermarket brake kits currently on the market that is the beauty of it AND you have better/improved steering as well as serviceable bearings that can handle the loads that sealed hubs can't
    sandiego74, rburrow87 and badazz81z28 like this.
  2. ErikNORCAL
    ErikNORCAL Veteran Member
    1,061
    Aug 6, 2003
    now in VA
    Should probably eBay my b-body ones before the market drops out when the new generation comes out lol.
    Nice design and target market!
  3. Jeep43
    Jeep43 Veteran Member
    1,246
    43
    Mar 30, 1999
    Connecticut
    That being said, how do these stack up against B-body spindles? I don't know enough about the GM parts to determine the difference based on your specs you listed.
  4. 79T/Aman
    2,452
    132
    Oct 7, 2004
    Dickson TN.
    20% stronger than stock GM B-body
    5% faster steering.
    Improved Akarman angle.
