2000 5.3 LS into 71, my progress/ lessons learned
Discussion in 'High Tech Retrofits' started by AlexSpinn, Sep 16, 2017.
  1. rustorbust
    rustorbust Veteran Member
    242
    10
    Dec 14, 2009
    San Diego
    Got any pictures or know what year S10 its off of. Did it clear the hood without having to cut any material out?
  2. 1slow70LS
    1slow70LS New Member
    Oct 18, 2017
    alternator was off a 2001 4.3L S10, No cutting required. Sorry I dont have any pictures, i pulled all my front end off for paint.
  3. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    No problem,
    Thanks
  4. 1slow70LS
    Oct 18, 2017
    Just a heads up I had to cut my tunnel to make room for my 2003 truck 4L60E.
  5. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    I already made the 4l80e fit without cutting anything.....;)
    1slow70LS likes this.
  6. AlexSpinn
    AlexSpinn New Member
    22
    Jan 31, 2017
    What engine mounts did you use?
  7. greencamaro1981
    greencamaro1981 Veteran Member
    604
    Jun 2, 2010
    Montana
    did the f body oil pan have enough clearance on the cross member? or did you have to notch the frame? im going to try and get mt 5.3 in this weekend and by the measurements its close to touching, do you have a pic from below showing where everything layed out?
  8. AlexSpinn
    22
    Jan 31, 2017
    I would recommend going with a different oil pan. Mine clears but its less than a half inch. It doesn't hit when idling or rpms up to roughly 3k but thats as high as I've taken it. I wouldn't be surprised if I have to swap oil pans down the line as I refuse to notch my crossmember. I won't be able to take a picture until this weekend. I used speedways ls swap motor mounts motor mounts
  9. Mike-78 Z-28
    Mike-78 Z-28 Veteran Member
    1,909
    Mar 4, 2003
    ElDorado Arkansas
  10. accelo
    accelo New Member
    9
    Jan 12, 2015
    washington
    Wiring was/is a breeze with LT1swap.com?
    Is the motor running? Did you purchase a harness from them or do your own.
    I believe this may be the most difficult part for many hot roders.
    Addrox likes this.
