2000 5.3 LS into 71, my progress/ lessons learned
Discussion in 'High Tech Retrofits' started by AlexSpinn, Sep 16, 2017.
  1. Seventy1ProTour
    Seventy1ProTour Member
    67
    14
    Oct 18, 2017
    Huntersville NC
    I will be starting my build soon, picked up an LQ4 6.0L and 4L80e combo. I'm planning to have the short block rebuilt with LQ9 Pistons for higher compression. Currently want to get Texas speed LS6 stg2 heads, LS6 intake and a nasty cam. Would be nice to be able to run an LS6 intake with truck accessories... There's a company that fabs those early gen3 intakes to accept a 90mm TB, may do that too. I'm hoping for 430rwhp.
    All these plans and haven't even received the pallet yet!! Haha
  2. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    Also, this will be my second LS swap. I did a 5.3LM7 and 700r4 combo(tuned as manual trans, spaced flywheel and hydraulically shifted) in a 1986 irocZ28.
  3. 71RSLS
    71RSLS Veteran Member
    760
    169
    Dec 5, 2017
    Prairie City, Ia
    I'm using some older ATS adapter plates and poly mounts in my 71. I'm setting it as far back as I can because I am using a Super T10. It'll be a while before I can actually get to work on it though.
  4. kyphur
    kyphur Veteran Member
    146
    Jan 4, 2008
    Huntsville, AL
    Good work!
