327 cqm choices
Discussion in 'Engine Topic' started by Its_not_a_transam, Mar 25, 2019.
  1. Its_not_a_transam
    Its_not_a_transam Member
    30
    Mar 23, 2019
    I have a 406 with vortecs and a magnum 280 waiting. Slicks...
  2. jeff swisher
    jeff swisher Veteran Member
    903
    222
    Apr 26, 2018
    Yes slicks and a beefed up rearend if you don't have one already :)
    I broke every stock GM 10 and 12 bolt I ever owned.
    Its_not_a_transam likes this.
  3. Its_not_a_transam
    30
    Mar 23, 2019
    8.5" 10 bolt.Eaton limited slip. 3.42 gear. Nothin special. I have two 80 camaros. The street car i dont really want too crazy. I will put the 406 in with the 4 spd. Eventually a tko600. Or t56. The stripped one i have(3100 lbs) is getting the 327 and a 4 spd. Maybe spray the hell out of it for a season.my plain is an lm7 5.3 with cathedral ports. 4.8 flat tops. And an ls9 cam with behive springs waiting for a turbo and my 4l80e. Just idle on a stand waiting.
  4. jeff swisher
    903
    222
    Apr 26, 2018
    Sounds like you have some goodies waiting to be played with.
    The LS9 cam looks like a heck of a turbo cam.
  5. Its_not_a_transam
    30
    Mar 23, 2019
    Im a craigslist junkie. Fb marketplace has made it worse. My little shop has motors everywhere. And parts. Just slowly piecing the LS swap together. My street car is meant to stop and turn. Dont want it crazy because i daily drive it.
  6. jeff swisher
    903
    222
    Apr 26, 2018
    I ported some LS heads 4 so far and there are spots in there that need removed.
    Do a port job and add an extra angle on the exhaust valve job.
    I am really impressed with my friends 6.0 with the ported heads and the GM LT4 hot cam.
    Used the masters off that cam for an LS grind and stuck it on a 109LSA.
    This camshaft.
    https://www.summitracing.com/parts/nal-24502586
    I think that puts it at .557" lift and about 2 degrees @ .050 more duration at .050 per .1 change on rocker arm ratio.
    That 6.0 swings to 7000 rpm quick and you need to keep your eye on the tachometer.
    130 seat pressure Pac springs at 313 spring rate and Morel Rollers.
