350 engine with only 100 hp?!?!?!
Discussion in 'Troubleshooting & Diagnosis' started by Galant, May 19, 2014.
  1. Scott Martin
    Scott Martin Veteran Member
    182
    Feb 10, 2014
    Bham Alabama
    First thing I would check would be the timing . Sounds like it is restarted as stated above. Try to advance the timing by turning the dizzy counter clockwise about 1/2 in. and see if that helps. If that's not it check your advance weights in the dizzy and make sure there not stuck, then check the carb. It's kinda hard to tell without more info. Like what kinda dizzy( mechanical or vaccum advance).
  2. kain13
    kain13 Veteran Member
    519
    Jul 6, 2006
    Lubbock,Texas
    check your trany fluid see if its the wright color
