350 sbc runs rough and blows smoke
Discussion in 'Engine Topic' started by Justin Berke, Jan 16, 2019.
  1. Justin Berke
    Justin Berke New Member
    29
    Jan 11, 2019
    British Columbia
    So I still have this problem with my Camaro, it won't idle and whenever I start it the throttle is almost floored and it will blow lots of smoke I assume it's the carburetor. It runs extremely rough and backfires when it is above 1400 rpm and it will die if I give it not enough throttle. My carb is a hr650 cfm quickfuel, and I have a mallory high volume fuel pump with a regulator. I just did the spark plugs and it's not the timing. I think it's the a/f mixture, I adjusted the 4 corner idle screws to factory settings aswell.
    Any ideas?
    Thanks,
    Thanks,
  2. cadillac_al
    cadillac_al Veteran Member
    847
    89
    Apr 22, 2015
    Maine
    I can't help with the carb but I would triple check the firing order.
  3. BonzoHansen
    19,496
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    What color smoke?
    Im assuming black and also wonder about timing issues.
  4. Justin Berke
    29
    Jan 11, 2019
    British Columbia
    Yea its black
  5. Justin Berke
    29
    Jan 11, 2019
    British Columbia
    Well actually more blue than black
  6. Bandit723
    Bandit723 Veteran Member
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Floats adjusted correctly? How many turns do you have the idle mixture screws turned out?
  7. Lowend
    15,056
    499
    Mar 25, 1999
    San Jose, CA, USA
    Blue tends to indicate burning oil. What I'm hearing is that the car runs badly, pretty much all of the time.
    Until we have an impression on timing everything else is kind of moot.
    Initial timing can be baselined at ~ 4deg BTDC at idle advancing to ~30 deg at 2500RPM
  8. Justin Berke
    29
    Jan 11, 2019
    British Columbia
    Well I was actually thinking maybe the floats are stuck, I may have to disassemble the carb. Have the idle mixture screws out factory settings 1.5 turns out.
  9. Justin Berke
    29
    Jan 11, 2019
    British Columbia
    Okay
  10. CorkyE
    10,448
    507
    First thing I would look at - stuck float, front or rear. As soon as you shut it off, put a rag under the carburetor and take the sight screws out. If gas runs out, you've found it.
