350 sbc runs rough and blows smoke
Discussion in 'Engine Topic' started by Justin Berke, Jan 16, 2019.
  1. COPO
    18,434
    1,076
    If your running a vacuum advance can then too much advance at idle will make her smoke like hell and rev up and down.
  2. John Wright
    14,718
    217
    Aug 9, 2002
    Rustburg, Va
    If the carb has been dumping raw fuel for a while, it may have washed the walls and rings down to the point where the rings have scored the cylinder walls....so what started out as a float set too high or float stuck, has turned into worn rings or scored walls causing blue smoke to appear.
  3. 1980RS
    1980RS Veteran Member
    3,701
    706
    Jun 17, 2006
    MN
    Are you running an Eddy carb or Holley?. Eddys are real bad for heat soak.
  4. CorkyE
    10,541
    550
    Initial post from OP says Quick Fuel, which is Holley type.
    OP - What high volume Mallory fuel pump and regulator do you have? What psi the the regulator set for?
  5. COPO
    18,434
    1,076
    It takes lots and lots of fuel to screw up rings if it was dumping it.
  6. Justin Berke
    Justin Berke New Member
    29
    Jan 11, 2019
    British Columbia
    I will try that the next time I get the chance, I was also thinking it may be the fuel filter
  7. Justin Berke
    29
    Jan 11, 2019
    British Columbia
    Set for 7psi
  8. budro6968
    budro6968 Veteran Member
    3,534
    622
    Apr 2, 2016
    Jax Florida
    Does the Holly quick fuel have the same type of power valve as the old school ones? My buddy had Holly in his Camaro. I hated to get stuck behind him going down the road. The Fumes would Kill me. I finally Got him to fix it. His went bad after a few backfires so it does not take much to pop it. I could see fuel just dumping down through the secondaries squirters while at Idle and partial throttle.
  9. CorkyE
    10,541
    550
    Electric or mechanical pump? If electric, we can determine if a float is stuck or adjusted too high real quick like. I don't think 7psi is driving past the floats but you may try taking it down a pound. Also, if you're using one of the mini gauges, especially the fluid filled ones, they're highly inaccurate when they get hot. I don't trust them past initial startup.
  10. Justin Berke
    29
    Jan 11, 2019
    British Columbia
    Its Electric
