350TH High RPM thump coming OFF gas
Discussion in 'Transmission & Driveline Topics' started by wwest, Sep 24, 2015.
  1. wwest
    wwest Veteran Member
    1,553
    Mar 29, 2000
    Chelmsford, MA
    Just found a thump/bang coming OFF the gas at high rpm that I think is coming from my transmission. I feel it in my feet.
    Absolutely no issues at low RPM. Shifts great. Shifts great at high RPM too....
    Goose the throttle here and there at lower RPMs - nothing.
    Stab the throttle, go through the gears to about 4k and yank your foot off the gas...In drive. Bang. No other issues.
    At 3k its more of a thump.
    Maybe a high pressure disengage problem?
    Maybe not the tranny? Maybe motor mount or suspension.....
    It seems more pronounced on a loooonnng pull through rpm.
  2. Dave Nelson
    Dave Nelson Veteran Member
    4,265
    1,992
    Dec 19, 2003
    Vineland N.J USA
    First I would check motor mounts, U joints, trans mount.
  3. wwest
    1,553
    Mar 29, 2000
    Chelmsford, MA
    I agree, in talking it to death with everyone this morning that's the consensus.
    Looks like I know what Im doing tonight....lol
  4. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    I'm onboard with the others...trans or motor mounts. Check the crossmember too.
  5. wwest
    1,553
    Mar 29, 2000
    Chelmsford, MA
    Well, jacked up the motor...mounts held solid. Motor and tranny.
    Im going to put a go pro under the hood this weekend and check it that way.
    It really sounds/feels like its the transmission disengaging. Like its banging into a freewheel status.
    But Im not giving up on mounts.
    More this weekend
  6. GoldenOne7710
    4,769
    377
    Jun 23, 2004
    Athens, GA
    You may not find a broken mount by just jacking up the enigne. You need to foot brake it while applying moderate throttle and have someone watch the engine/trans movement under a load. Try it in forward and reverse.
  7. wwest
    1,553
    Mar 29, 2000
    Chelmsford, MA
    OHHHH I like that idea.
    I am thinking its ripped at the top and it takes time and TQ to squeeze it through. Then off the throttle it drops a half an inch and bang.
    Ill find out soon - and let you know.
  8. Marv D
    10,851
    May 12, 1999
    Devils own training ground,,, aka Arizona
    Wade check the U-joints too.
    Your putting some decent torque through that trans,, it wouldn't surprise me if you have torn up some thrust shims and it's wanting to come apart. How long has it been since the trans was freshened?
    Also arent you running solid body mounts? (just another thing to check)
  9. 496z28
    496z28 Veteran Member Lifetime Gold Member
    965
    8
    Sep 23, 2007
    Oklahoma City
    Loose torque converter bolts?
