355 w/ tall valve covers-will AC brackets fit?
Discussion in 'Engine Topic' started by ddc456, Aug 18, 2011.
  1. ddc456
    ddc456 Veteran Member
    490
    Oct 11, 2010
    Oregon
    My dad has a brand new built full roller 355 which will require taller valve covers. Now will my original AC brackets fit going up and over the valve cover on the drivers side of the motor????
  2. ddc456
    490
    Oct 11, 2010
    Oregon
    If not what options do i have for brackets???
  3. John Wright
    13,932
    42
    Aug 9, 2002
    Rustburg, Va
    I doubt the original brackets for the A6 compressor will fit over a tall set of covers. You may have to go to a different assy drive kit that mounts the compressor out a bit farther.
  4. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,375
    Mar 30, 2001
    Joplin Mo. 64801
    The bracket over the valve cover is not a MUST, leave it off and go cruising.
  5. Twisted_Metal
    25,268
    286
    I am using a set of cast aluminum covers which are only a fraction of an inch taller than factory... The factory bracket fits with just enough room to floss between the cover and bracket.
    "Tall" covers aren't going to fit.
    You can probably leave the upper bracket off if you have the one on the lower portion of the compressor connected to the header/manifold bolts.
    Like this guy did...
  6. 80-z28
    80-z28 Veteran Member
    521
    Apr 20, 2009
    New Orleans, La
    This is what I did with mine.
