4.2 inline 6 banger
Discussion in 'The BS Topic' started by ol' grouch, Aug 18, 2016.
  1. ol' grouch
    ol' grouch Veteran Member
    2,878
    783
    Jul 4, 2013
    Evansville, In.
    I've got someone wanting to trade for my Mercedes 300 S class diesel. They want to trade an '04 Buick Ranier. It has the 4.2 inline 6 cylinder. I know the car is basically a Buick version of the Tahoe. If it was the 4.3 V-6 I'd pass as the intake and fuel system problems they had are more than I want to fight. How good is this drivetrain and the vehicle overall. It's a bit battered but I want something to drive if we have a bad winter with lots of snow.
  2. Shizzle
    Shizzle Veteran Member
    2,386
    485
    Aug 1, 2012
    oak lawn, illinois
    Trailblazer I'm guessing you meant, Tahoe was a full size V8
  3. Mike N
    2,750
    523
    Jan 13, 2002
    Spencerport, NY.
    If the Rainier has been exposed to a bunch of road salt I would pass. They rot pretty badly underneath, and it's big ticket items that attract the most rust.
  4. camarolife78
    camarolife78 Veteran Member
    545
    Jul 22, 2014
    Gardner, KS
    I would pass... the 4.2 can be costly to repair and they have some quirks that come up. Examples:
    The valves can get carbonned up, which end up causing a p0300 misfire.
    They also have frequent p0011 codes, which tend to come from lack of oil changes...most the time it is just a simple control solenoid for the cam phaser, but every once in a while you will have to also change the cam phaser as well to get it back right.
    The catalytic convertors go out quite frequently. My uncle has the GMC version...on his 3rd convertor.
    The front 4wd (if it has 4wd) actually mounts to the oil pan and goes through it. Kind of cool...but I have seen a few problems pop up with the RH side of the differential that mounts to the oil pan..
    The TStat is a pain to change...causes a frequent P0128 code.
    The water pumps tend to slowly fail / wear out. They get a lot of play in the shaft bearings but don't leak. When they finally decide to leak its a lot and fast with minimal warning.
    The Electronic clutch for the mechanical fan tends to give some issues, not as much at the water pump.
    Oh and forgot to mention, the clutch fan and shroud are a pain to remove, UNLESS you cut a relief in the fan shroud around the upper radiator hose outlet.
    Those are the issues I see frequently come into the shop. There are also the typical GM wheel bearings and suspension parts, but that's about given on every car.
    Hope this helps!
  5. Mike N
    2,750
    523
    Jan 13, 2002
    Spencerport, NY.
    The VVT solenoid, thermostat, fan and water pump are all easy fixes.
    The power steering lines, tranny cooler lines, fuel pump and converter are common and expensive fixes. Brakes, ball joints, wheel bearings, tie rods, swaybar links are to be expected on these heaps. The frames on those like to rot out near the front wheels, especially on the passenger side.
    I would still pass.
  6. fatkid_racing
    fatkid_racing Veteran Member Lifetime Gold Member
    1,049
    90
    Sep 21, 2005
    Saginaw Texas
    So it's pretty much like any other used car on the road?
  7. ol' grouch
    2,878
    783
    Jul 4, 2013
    Evansville, In.
    I may pass on it. The picture of the car had Wisconsin plates on it. They want my van which has electrical problems with the transmission. It will shift with the shifter but stays in third gear going down the road. No grinding or anything, just no shift. Otherwise the van is a decent one so I'll stay with it and see if I can troubleshoot the electrics.
  8. Mike N
    2,750
    523
    Jan 13, 2002
    Spencerport, NY.
    Frequency of repair on the Rainier/Trailblazer/Envoy is higher than most others.
  9. 1BAD78
    1BAD78 Veteran Member Gold Member
    814
    Apr 12, 2007
    Broken Arrow Ok
    Fixed :crazy:
