4-relay power windows - Do it!
Discussion in 'Electrical Systems' started by Tokyo Torquer3, Nov 12, 2012.
  1. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    Here are the added terminals and connectors needed for a factory style install...
  2. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    Here is the OEM power window relay-it is mounted above the steering column brace. The only 2 wires you'll need to re-use for my auto down relay upgrade is the PNK/blk (switched IGN) and ORN/blk (battery power). These you can either insert into my 2-cavity connector or, if you're are corroded or missing, I include 2 new terminals for you to crimp/solder.
  3. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    I also include a color coded installation diagram for use exclusively with my harness kit-I also make a slightly different version of this harness for use on 80-81 models too. If anybody is interested, PM me for details. I build when ordered since I also use these solid state modules on a variety of harnesses-typical lead time is a week.
  4. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    These are still available if anybody is thinking about upgrading and want to keep a stock-ish appearance. Auto down is still an option and if you opt to upgrade to a late model replacement motor/window track with a reverse polarity motor, then I can also integrate auto down AND up.
  5. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    ttt
  6. Tokyo Torquer3
    Tokyo Torquer3 Veteran Member
    2,187
    Oct 14, 2003
    NJ
    It has been some years since I did this mod and I am still amazed today how fast the windows go up and do after living for years with the car with power windows that just creeped up with the stock wiring.
  7. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    I have a kit going to a member in australia so I built 3 kits while building his-this is what it consists of:
    Auto down
    HD relay conversion
    Setup for late model reverse polarity motors which require a different switch
    I've been building many variations of my kits.
  8. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    This version is a full kit with auto down, NEW late mode style switch and door grommets. This one is for use with newer style reverse polarity motors.
  9. CAMeeks
    CAMeeks Veteran Member
    697
    42
    Jan 5, 2014
    Deer Park, TX
    I wish I knew you had grommets.
  10. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    Well the guy asked if I stocked them and while they aren't 2nd gen specific, since his was manual and not power to begin with, these will work-they are GM style after all.
