4-relay power windows - Do it!
Discussion in 'Electrical Systems' started by Tokyo Torquer3, Nov 12, 2012.
  1. dailycruiser81
    dailycruiser81 Veteran Member
    207
    10
    May 19, 2013
    ft lauderdale
    What is the pricing on these kits? I have an 81 with factory power.
  2. CAMeeks
    CAMeeks Veteran Member
    697
    42
    Jan 5, 2014
    Deer Park, TX
    Mine was manual also. Can you pm me the info on the boots?
  3. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    Door boots are $45/pr shipped. The relay kits for 80-81 only differ from 70-79 at the fuse panel and don't require a switched IGN control relay-those relay kits are $209 shipped. If you want auto down it'd be $249 shipped.
  4. Budjet drain
    Budjet drain Member
    90
    Dec 3, 2016
    Wallisville TX
    Are you still making these harnesses?
    I have a 79 Z28 and will be rewiring the whole car. Currently don't have electric windows installed. Looking for recommendations on window motors OEM/Electric Life? Also need power locks, any sugestions?
  5. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    I have power window relay kit w/HD relay upgrade as well as auto down/up if you want that feature. I'd suggest Electric Life as they are the most compatible-and Nu-Relics kits make you buy their harness which by comparison is garbage and nobody else offers any kind of window upgrade anyway. As for power locks, have you looked at Spal?
  6. Budjet drain
    Budjet drain Member
    90
    Dec 3, 2016
    Wallisville TX
    Thanks for the advice. Looks like I will be ordering the Electric Life kit. If I also would like to order one of your harnesses with express up/down.
    As for the Spal lock actuators, will they mount in the factory location or will I need to drill additional holes in door?
  7. Budjet drain
    Budjet drain Member
    90
    Dec 3, 2016
    Wallisville TX
    JunkyardZ28find have you shipped my harness yet? Haven't received any tracking info, if you have.
  8. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    PM sent!
  9. BP80Z28
    BP80Z28 Veteran Member Lifetime Gold Member
    1,153
    Sep 2, 2008
    Plymouth Mass
    Photobucket ruined everything. Now that I'm ready to do this. You can't see the pics. If any body has copies of this would be great.
  10. BP80Z28
    1,153
    Sep 2, 2008
    Plymouth Mass
