4 speed hump....
Discussion in 'Body Restoration' started by garyandcindy, Jan 9, 2011.
  1. garyandcindy
    garyandcindy Veteran Member
    1,603
    Oct 20, 2004
    cumming,ga-usa
    Didn't really know where to put this.Put in the interior section but not much response.Is the transmission tunnel marked at the factory any sort of way for the location of the 4 speed shifter hump on a automatic transmission car.Any body got a picture of this area.I've done a search and some say that they are dipples on the tunnel where it should go on auto transmission cars.
  2. krabben1
    8,098
    10
    May 16, 2007
    ( . Y . )Delco
    I will try again this afternoon for you.I saw your other post yesterday and went down to get pics for ya,but I was having trouble getting the measurments to fit inside the pic I was trying to take,lol.I'll split them up with a start point and an end point for front and back.
  3. garyandcindy
    1,603
    Oct 20, 2004
    cumming,ga-usa
    That would be great.Thanks.
  4. KansasTwister
    KansasTwister Veteran Member Lifetime Gold Member
    1,389
    Oct 7, 2006
    Lawrence, ks
    Although not factory, you can see where the shifter sits. The round hole to the rear right is where the cable went through. I never cut it out to full size of the factory hole, just to what it needed.
  5. krabben1
    8,098
    10
    May 16, 2007
    ( . Y . )Delco
    Fixed.
  6. krabben1
    8,098
    10
    May 16, 2007
    ( . Y . )Delco
    Here's an under shot to show you what they did cutoutwise.
  7. garyandcindy
    1,603
    Oct 20, 2004
    cumming,ga-usa
    Wow! It looks like they cut out alot from the factory.So it's really not necessary to cut out as much as they did.Cut just enough to get the shifter thru and the hump needs to be in the right place for the boots and console.
  8. krabben1
    8,098
    10
    May 16, 2007
    ( . Y . )Delco
    I would do what they do.Its never good to have to much metal overlap.Rust can fester in there.Looks like they traced the inside of the hump and cut.And on the inside,they let a monkey fingerpaint with the seamseal,lol.
  9. bob licher
    bob licher Veteran Member
    170
    Feb 28, 2010
    lake havasu az
    hey what happened
  10. bob licher
    170
    Feb 28, 2010
    lake havasu az
    what happened to the pics? Bob
