400 SBC in 4/5th gen
Discussion in 'Camaro Questions' started by locke2904, Apr 28, 2019.
  1. locke2904
    locke2904 New Member
    Jun 9, 2010
    central, louisiana
    This seems like it may be the most ridiculous idea possible, but... will a 400sbc fit in a 4th or 5th gen camaro?
  2. dave@ztech
    3,475
    714
    Mar 27, 2016
    NY
    It should , with several mods, but why would you, when the engine that does fit, will make double the power, easier, then the SBC 400
  3. rchydzik
    836
    23
    Nov 13, 1999
    Colbert, WA USA
    It should fit in a 93-97 fbody with the LT1. The low hood will preclude any sort of carburetor, so you would need a low profile fuel injection manifold. I agree with Dave, an LS swap would be much easier.
  4. locke2904
    Jun 9, 2010
    central, louisiana
    I put a 350 in a 2008 camaro in 3D for a college project.
    I have a 400 sitting around in a mangled 78 camaro body, (torqued the crap out of it). Figured I may attempt my project irl. I can’t find another 2nd gen and can’t afford a first gen. Plenty of 4th and 5th at the jy.
  5. Rich Schmidt
    Rich Schmidt Veteran Member
    4,278
    38
    Mar 27, 2010
    Denville NJ
    The distributor will be the biggest problem. I don't know about on a 5th gen but on a 4th gen it is a no go.
  6. badazz81z28
    16,912
    500
    Las Vegas, NV
    The problem is the motor slightly tucks under the cowl. The distributed and any carb set up would not likely be easy to retro swaps. Maybe if you put a TPI set-up on it, might help
