400 turbo,,pan bolt
Discussion in 'Transmission & Driveline Topics' started by 2nd gen man, Nov 15, 2013.
  1. 2nd gen man
    2nd gen man Veteran Member
    991
    Nov 28, 2010
    michigan
    well,,,as Bad luck comes around..
    while install of my new trans pan, I stripped a pan bolt while
    being careful not to overtorque the bolts.
    wonder if I should drill and tap the next size bigger in metric
    I believe the stock size is 3/8''...dont' really want to drill out to
    1/2'' size...
    anyone else thoughts'
  2. LidyGraphics
    LidyGraphics New Member
    28
    Mar 22, 2010
    Effingham, IL
    take the bolt to an auto parts store and get a helicoil kit.
  3. dale68z
    dale68z Veteran Member
    1,310
    May 14, 2009
    Glendale Arizona
    Sometimes you can install a longer bolt. Especially if it is a open ended hole. The longer bolt will catch good threads. Just be sure the bolt does not bottom out.
    The bolts are 5/16, not sure if t 400's ever came with metric pan bolts. If they did it would be 8mm
  4. 2nd gen man
    991
    Nov 28, 2010
    michigan
    thanx, guys
    I am going to check on a helicoil kit tomorrow
    and the bolt size is 5/16 '' I was thinking I could use a
    metric size say,8mm or 9mm that was just a little larger
    dia. its one of the front bolts that is stripped.
    thanx' again
  5. mrdragster1970
    7,822
    507
    Apr 12, 2007
    If there is enough meat, I would just helicoil it.
    I don't have any 400's to look at the surrounding area.
    I frigging hate working on stuff that guys 1/2 assed with mixed sizes & bolt types.
  6. Fbird
    3,245
    363
    Feb 12, 2011
    atlanta, ga
    it's 5/16 - 18 UNC thread size. NO you do NOT want to install a metric bolt in said hole. It's just unwise as you KNOW the next time you are inn this thing.....trying to reassemble the pan....at 1:00 am about a 12 pack into the job........freezin your azz off......YOU will grab that 1 unidentified metric bolt and plow it into a GOOD hole......then you will have 2 screwed up holes in the case.
    garuanteed by MURPHY
    Spend the $20 accept you screwed up.....heli-coil it and move on.
  7. 2nd gen man
    991
    Nov 28, 2010
    michigan
    well,,,thanx'
    for all the tips guys,,,
    I was lucky enough to use a longer 5/16''bolt and the
    threads let me torque the bolt down..
    fbird,,no metric,,,,lol
    just more soda....lol
