454 BBC swap 79 Z28
Discussion in 'Engine Topic' started by mcmurphy2121, Jan 1, 2012.
  1. mcmurphy2121
    mcmurphy2121 New Member
    10
    Dec 27, 2011
    calgary alberta
    hey everyone im doing a 454 swap on my 79 camaro Z28 and was just wondering if anyone had some helpfull hints of pictures any help would be great before i tackle this project full force :bowtie: :bowtie:
  2. 450bench
    450bench Veteran Member
    3,128
    41
    Feb 25, 2002
    memphis, tn-shelby
    Put this 427 in place of a 350...No problems at all...Used the 350 motor mounts, bought some alternater brackets and a cheap set of Summit headers and bolted it right in...With a flat hood I would have run a Torker II or old Edelbrock streetmaster for hood clearence but did some trimming on the z28 hood and ran a Weiand 8013 dual plane...I did put new small block TRW front coil springs in it to keep the front end up...If you run stock clam shells on it you may have to grind a bit off the drive side shell to clear the headers...I had to do that...That car was a real sleeper and was lazer straight with absolutely zero rust......It was a real L88 short block with an original L88 cam and 781 heads with 2.25s and 1.88s...I ran Schubeck solid lifters in it...M-21 4 speed and 4.10 gear...Ran 11.80s w/10.5 slicks all day and if I could have shifted better it would easily run 11.50s...Sold it to a friend who changed to an UltraDyne 630 solid, Strip Dominator, Powerglide, 4 point cage and 4.56 gears and went 10.90s
  3. Rumpity_z28
    Rumpity_z28 Veteran Member
    404
    Jul 27, 2004
    Hope B.C.
    wow that looks like a factory install, were putting a 454 in the gf's car after i finish up the bodywork. were going to keep the stock manifolds to keep costs down and keep it simple.
  4. 450bench
    3,128
    41
    Feb 25, 2002
    memphis, tn-shelby
    It's really an easy job...No major mods of any kind...Just drop it in
  5. mcmurphy2121
    10
    Dec 27, 2011
    calgary alberta
    nice pics man ya i have bud luck so i just wanted an idea of whats going on so i dont run into a lemon lol
  6. 450bench
    3,128
    41
    Feb 25, 2002
    memphis, tn-shelby
    You'll get it done with no problems at all...
  7. mcmurphy2121
    10
    Dec 27, 2011
    calgary alberta
    lol hopefully what kinda tranny do you think i should go with and suspenstion?
  8. 450bench
    3,128
    41
    Feb 25, 2002
    memphis, tn-shelby
    Stock suspension...If it currently has an automatic, do that...4 speed? Do that...Keep it simple
  9. mcmurphy2121
    10
    Dec 27, 2011
    calgary alberta
    ya if i remember right it is a 4 speed
  10. 71RS/SS396
    71RS/SS396 Veteran Member
    2,627
    30
    Aug 26, 2008
    Wake Forest NC
    You're going to need a different flywheel for the 454 because it's externally balanced and the 350 is internally balanced.
