454 HP calculation
Discussion in 'Engine Topic' started by Scott Martin, Dec 17, 2016.
  1. Scott Martin
    Scott Martin Veteran Member
    182
    Feb 10, 2014
    Bham Alabama
    I have recently had my 454 rebuilt and dynoed by a local shop. I think the dyno #s are a little low and I would like some input please. The motor is a mark 4 454 bored .030 with stock stroke and rod length. Pistons are 23 cc SRP small domes. Claculated compression by the shop that put it together was 9.68. It has Brodix RR 270cc ovals and a hydraulic roller cam , .241 and .249 @ 50. Lift is 625 , 625 on a 110 and the lifters are Comp Cam short travel rollers. The intake is a Holley strip dominator with a Holley 850 street HP carb. It also has Hooker comp headers. It made 516hp and 529ftlbs all before 5400 and started dropping from there. Does this seem correct or do I have issues somewhere ?
  2. Scott Martin
    182
    Feb 10, 2014
    Bham Alabama
    I forgot to mention the spring pressure , seat is 150 and open is 385. Max lift .650 and spring height is 1.945
  3. 77 cruiser
    77 cruiser Veteran Member
    440
    12
    Nov 17, 2006
    Frostbite Falls MN
    Do you have a full readout from the dyno?
  4. Scott Martin
    182
    Feb 10, 2014
    Bham Alabama
    I should have the readouts Tuesday when I pick up my motor. I watched them do about 5 pulls from 3500 to 5500 and 1 pull to 6000. I took a picture of one of the readouts because his printer was acting up. It was with their shop carb that was a 650 dp. I will try and post the the graph I have
  5. Scott Martin
    182
    Feb 10, 2014
    Bham Alabama
    I have been trying to upload the graph and I can not get it to load. I will keep trying to get the picture to load
  6. CasperCasper
    CasperCasper Veteran Member
    955
    90
    Aug 11, 2015
    I'd say that seems low. Does it have conservative ignition timing perhaps?
  7. Scott Martin
    182
    Feb 10, 2014
    Bham Alabama
    He only ran it on 36 deg. He did not change the timing on any of the pulls that I saw. I think that the #s are low also. I know they have been having trouble with the dyno. My motor has been on a stand at their shop for a month waiting on the dyno to be repaired. The dyno was loosing its load at 4500 rpms before. I think my motor was the first one on the dyno since it was taken apart and repaired
  8. Scott Martin
    182
    Feb 10, 2014
    Bham Alabama
    I hope you can read these , if you need any more info I have the dyno sheets in hand now 20161219_165734.jpg 20161219_165739.jpg 20161219_165756.jpg 20161219_165830.jpg
