454 running hot
Discussion in 'Engine Topic' started by sfmperformance, Nov 7, 2015.
  1. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Definitely need to test with another gauge or 2.
  2. 77 cruiser
    77 cruiser Veteran Member
    537
    24
    Nov 17, 2006
    Frostbite Falls MN
    How about checking the thermostat, or a different one.
  3. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Check temp with another guage, and make sure to have proper shrouding around the cooling fans.
  4. COPO
    17,678
    680
    No shroud = over heating issues
    High flow pump = over heating issues
    Too cool T-Stat = engine wear issues
    Incorrect timing = over heating issues
    on and on......
  5. 76z28
    76z28 Veteran Member
    2,005
    46
    Jun 29, 2009
    bakersfield
    A high flow pump wont cause over heating issues.
    The Radiator is basically a heat sink.. The more you can push through it the more it will cool.
    As for OP.. Stock pulleys?
  6. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    I have to agree with COPO. I have seen a high flow water pump cause a car to overheat, because it was moving the coolant too quickly through the radiator which didn't allow enough time for the fluid to cool.
  7. Mike N
    2,736
    519
    Jan 13, 2002
    Spencerport, NY.
    The high flow water pump can also push the water thru the engine too quickly, not allowing it enough time to pick up the heat.
  8. JONESYFXR
    2,177
    Oct 10, 2009
    BUFFALO, NY
    ^^Good Point^^
  9. 76z28
    2,005
    46
    Jun 29, 2009
    bakersfield
    You cannot push water in "too quickly" through a block.
    The more flow the better cooling.
    I would almost guarantee the person had under drive pulleys or some poo that caused the issue.
    More water movement both through the block and radiator will always cool better. Water will conduct the same moving slowly as it will moving quickly, its a matter of pressure and volume that you must look at.
    As pressure increases the less likely water is to boil or "flash"
    The more movement from the more volume will give a better cooling effect. You make the point of it moving too quickly. Water doesn't care how fast its going.. its still surrounded by hot metal and will take away heat.
    Straight from Stewart Componenets:
    Q1. Will the Stewart Hi-Flow water pump reduce my cooling temperature?
    A1. Yes. The water pump is the heart of the cooling system and flow should always be maximized to reduce temperatures.
  10. vegas1974z28
    4,648
    112
    Jan 10, 2002
    Las Vegas,NV
    I believe this was discussed here once or twice.
    And I'm pretty sure the consensus was too much water pump was a wives tale.
