4th Gen Radiator in 2nd Gen LS Swap
Discussion in 'High Tech Retrofits' started by James_slowmaro, Feb 16, 2020.
  1. James_slowmaro
    James_slowmaro New Member
    Feb 12, 2020
    I have been researching through a couple sites and have read mixed reviews about putting a 4th gen camaro radiator and fan assembly in a second gen. What all is needed for this swap? Also where does the steam line go to on the 4th gen rad?
  2. Green hornet
    Green hornet Veteran Member
    1,789
    341
    Oct 11, 2015
    North Bay, CA
    I put the 4th gen fans in but not the 4th gen radiator. The fans were an easy install no mods needed. Now if you currently have a the small radiator you will need to upgrade to the larger radiator and that will also requires enlarging the opening in the core support.
  3. badazz81z28
    17,395
    604
    Alabama
    It’s 2020...you can buy a “LS” style radiator that’s a direct bolt on for a 70-81. Steam line and the hose connection are in the correct place.
