4th gen seat belts
Discussion in 'Interior Restoration' started by Mountaineer, Jul 1, 2007.
  1. Mountaineer
    Mountaineer Veteran Member
    2,092
    8
    Mar 6, 1999
    Where Mountaineers are free
    I'm going to do the swap in my '81 to the 4th gen belts (at least the front ones). I spoke with a knowledgeable boneyard and the said that different 4th gen body styles (T-tops, convertible, hardtop) are different kinds, and also different years may be different. I've done a search on this forum of folks doing this swap successfully, which style and year did you use?
  2. sceld71
    sceld71 Veteran Member
    1,067
    Nov 9, 2005
    Plain City, Ohio
    2 1/2 years later, any status updates?
  3. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Been done by quite a few members. Front and back.
    If you can't find it with the sites search feature.
    Use Google, I've had better luck with it.
  4. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    My front 4th gen belts were from a hardtop. It was a '95 if I recall correctly. I also compared these to some from a '98 - and they were the same.
    I bolted them directly into my '80 w/ t-tops. I had to cut the trim plate a little, but you wouldn't know it unless you were really looking closely.
    I can see the 4th gen convertible belts being different, but I bet the hardtop and t-top belts are the same. I have not checked the part numbers to be sure though...
  5. joshp01
    joshp01 Veteran Member
    808
    Aug 20, 2010
    Amarillo, Texas
    Yes hard top and ttop belts are the same on fourth gens. My 72 doesnt have a space on the roof to attach the shoulder belt. I guess it came factory w lap belts? Who knows haha
  6. morrisclassic
    morrisclassic Member
    98
    Jan 23, 2007
    South Carolina
    3 point seat belts for 75-92
    It would be a lot safer and easier to just order new ones from us.
    They are a direct bolt in for 75-81 and 82-92.We have the GM Mark of Excellence on the buckles. Colors too.
    Morris Classic Concepts, Billy
  7. BonzoHansen
    19,639
    903
    Jun 1, 2005
    Scott from Hamilton, NJ
    Sweet news Billy!
  8. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
  9. Ryan 79
    Ryan 79 Veteran Member Lifetime Gold Member
    3,299
    Mar 29, 1999
    Granite Falls, WA
    I ran into this problem. I took my 4th gen seatbelts out of two different wrecked cars in a junkyard. One was destroyed on the drivers side, the other on the passenger side
    I don't know what years they changed, but THEY ARE DIFFERENT. I ended up having to use the female ends for the backseat as the female ends for the fronseat, and I had to use the stock belts for the backseat because I didn't have enough correct parts to make a full set.
    So if you get belts out of two different cars, make sure they're the same. It never occured to me they'd be different, so I didn't check when I bought them.
    OOPS
