5.3 questions
Discussion in 'High Tech Retrofits' started by irocjoecool, Apr 14, 2015.
  1. irocjoecool
    irocjoecool New Member
    12
    Apr 13, 2015
    United States
    I have a 1978 LT Camaro.
    Will a 5.3 with truck accessories and a truck intake clear if I have a cowl hood?
  2. JWZ28
    JWZ28 Veteran Member
    1,237
    Feb 27, 2011
    Alabama
    I would think so, I'm fairly certain the 5.3 would sit lower than the air cleaner/carb setups we typically run on our cars. How tall is your cowl?
  3. irocjoecool
    12
    Apr 13, 2015
    United States
    Where in Alabama? Montgomery here
  4. JWZ28
    1,237
    Feb 27, 2011
    Alabama
    I'm in Hartselle, about 15 min South of Huntsville
  5. jb451
    jb451 Veteran Member
    861
    Jan 17, 2011
    Mesquite, Texas
    Yes. My truck intake clears with a 2" cowl. The only spot you will have to massage is the spot over the alternator, the hood will close but it rubs. I would almost bet you could fit it under a stock hood if you shaved the intake.
  6. irocjoecool
    12
    Apr 13, 2015
    United States
    A/C fit also?
  7. jb451
    861
    Jan 17, 2011
    Mesquite, Texas
    In stock trim? no, the frame is in the way.
  8. irocjoecool
    12
    Apr 13, 2015
    United States
    Any aftermarket brackets that will let you stay mostly stock truck, and move A/C?
  9. Camaro-Chevelle
    Camaro-Chevelle Veteran Member Lifetime Gold Member
    222
    Sep 22, 2007
    Long Island, New York
    For anyone interested, these are the parts that I used for the short Corvette Water Pump configuration:
    Water Pump ~ AC Delco 251-726
    Power Steering Pump ~ AutoZone 63106
    Power Steering Reservoir Kit ~ Holley 198-200
    Power Steering Pulley ~ Chevrolet Performance 12568997
    Driver Side Bracket Kit for Alternator and Power Steering Pump ~ Holley 20-135
    Accessory Drive Bracket Kit for SD508 A/C Compressor ~ Holley 20-132
    Harmonic Balancer ~ ATI Super Damper 917266
    I was able to use the truck alternator that came with the 6.0.
  10. OsborneConst
    OsborneConst Veteran Member Lifetime Gold Member
    1,011
    Oct 25, 2009
    Kalamazoo, MI
    I used dirty dingo mounts on mine. You can get just a bracket for your A/C. I got the one that uses an R4 compressor so that it runs off from the serpentine belt, but the have all different options. I also used their mounts that let me use the truck alternator, and P/S pump with the LS1 car intake. By using the truck P/S pump, I was able to easily use the truck hydra-boost brake system, including all of the lines and hoses too.
