5.3 swap fuel system HELP!!!!
Discussion in 'High Tech Retrofits' started by Gbrumf22, Apr 13, 2015.
  1. Gbrumf22
    Gbrumf22 New Member
    Apr 7, 2015
    Texas
    I am swapping a 5.3 into my 1980 z28 and i had question about the fuel system
    1 I wanted to run a in line fuel pump because it was a cheaper option,if i
    were to put this on my car do i just run a hose to my tank or what??? i have been told that i would need a sump? What internals do I need in my fuel tank.
  2. Knuckle Dragger
    15,175
    1,650
    Nov 2, 2002
    Waddell AZ
    This is a little better suited for this section.
  3. Stx 09
    Stx 09 New Member
    14
    Nov 16, 2012
    Texas
  4. Stx 09
    Stx 09 New Member
    14
    Nov 16, 2012
    Texas
    Found that in the sticky in the High tech retrofits post.
  5. Iknow2
    Iknow2 Veteran Member
    137
    Aug 6, 2014
    Houston, Texas
    Use TANKS inc, best bang for the buck
  6. badazz81z28
    17,406
    605
    Alabama
    I would just use the spectre tank. Trying to mod the tank can be tough if you have no fab skills.
  7. jb451
    jb451 Veteran Member
    861
    Jan 17, 2011
    Mesquite, Texas
    Not that i would advise it (although i have had no issues, its still a janky setup), but i cut the sock off the pickup tube, and with a piece of EFI hose attached the pump to the tube. You will have to disassemble the sending unit (possibly screwing it up) to get it in the tank. Like i said, not recommended but it is the cheapest option to get an in-tank pump. Personally, i would just spend the money on the spectra or tanks inc kit, if for nothing else, the piece of mind. Look at my swap thread in here for pics.
