5.3 truck engine converted to 5.7 LS1
Discussion in 'High Tech Retrofits' started by ctchap70, Jul 24, 2011.
  1. ctchap70
    ctchap70 Veteran Member Lifetime Gold Member
    1,469
    Apr 29, 2002
    Fort Necessity, Louisiana
    Anyone know what is involved? Anyone on here done it?
  2. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    Your better off from what I have read is starting with the 5.7 if that is what you want. Otherwise the 5.3 can be made to make just as much power.
  3. Todd80Z28
    11,387
    176
    Jun 11, 2002
    Northern VA
    The difference is the bore. They share the same stroke. I'm not sure if you can bore out a 5.3 block that far... maybe?
    I suppose the better question is- with the availability of all the other LSx stuff out there, why bother?
  4. ctchap70
    1,469
    Apr 29, 2002
    See what I thought about was using the motor an trans from my 05 silverado after it gets paid off not too long from now. Just a thought.
  5. Pfrederiksen
    Pfrederiksen Veteran Member
    609
    Feb 21, 2011
    Edmonton,Canada
    Sure you can. You end up with an iron block LS 1.
    Pretty cool.
    P
  6. ProStreet383
    ProStreet383 Veteran Member
    2,106
    9
    May 23, 2007
    MD
    And then do what with the truck? Seems silly to me when you can find a good 6.0 out of a wrecked truck and the 6.0 is a much better engine than the 5.3 or 5.7 lsx.
  7. ctchap70
    1,469
    Apr 29, 2002
    Well it's like this, my truck has 105k miles on it. It had 27k on it when I started using royal purple an k&n filters. So I know I got a good engine an trans, computer & all accessaries. The truck has a lemon title, though I've not had a lick of trouble wit it. Some minor body damage, yup a deer, so I don't know how much I could sell it for. I got the 5.3 to 5.7 from a car craft article a couple mths ago. But they didn't get detailed in the conversion and had plenty of parts at their disposal. So anybody done this on here before? Thanks again, Charlton.
  8. rajent
    rajent New Member
    Jan 15, 2010
    St.Pete,Florida
    5.3 to 5.7 ls1
    there is a book titled "how to build high performance chevy ls1/ls6 v-8s"
    by Will Handzel that explaines this in great detail including GM part numbers for
    needed parts.The 5.3 cast iron block needs to be bored to 99 mm.but the block
    should have enough "meat"to allow machining that far.
  9. ctchap70
    1,469
    Apr 29, 2002
    Thanks. Think I'll look it up. Charlton.
  10. 77nomad
    77nomad Veteran Member
    2,123
    Nov 20, 2009
    Ski Town
    This months issue of HotRod has a interesting 5.3. Twin turbo. Stock bottom end. 1200hp. The pulled it apart and found out it was a 4.7, so they say.
