5.3L into 89 s-10
Discussion in 'High Tech Retrofits' started by alknopf, Jan 20, 2006.
  1. alknopf
    alknopf New Member
    Jan 20, 2006
    I was wondering if anyone knows what has to be done to use a th350 trans with a 1999 5.3L? Also... does anyone know if the engine wiring harness from a 5.3L controls the 4L60E transmission or does it have a seperate control module?
  2. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Ttt...
  3. jakeshoe
    8,869
    Dec 8, 2000
    Republic of Texas
    To use a Th350 trans you need a flexplate, adapter, and bolts used to put the 4L80E behind a 6.0L.
    I don't have the PNs handy or I would post.
    The PCM electronics control the trans. Same controller for the motor, they are not seperate.
  4. alknopf
    alknopf New Member
    Jan 20, 2006
    thanks
