5gen 2012 Camaro center console in my 1970
Discussion in 'Interior Restoration' started by Tpichevy, Feb 25, 2017.
  1. CaliCamaro75
    CaliCamaro75 Veteran Member
    439
    31
    Sep 6, 2015
    Winchester,CA
    Just got mine today. Previous owner had put some type of courtesy lights for the foot wells on the console. May keep them there or remove. But first must fab some seat brackets to see if the console will even fit. If not will be making my own console from steel sheet
  2. Revin
    Revin Veteran Member
    555
    92
    Aug 31, 2016
    Round Rock , TEXAS
    I grabbed one as well. $150 could not pass up. Not sure if I will use or not...yet. long way till then.
  3. CaliCamaro75
    439
    31
    Sep 6, 2015
    Winchester,CA
    Yea im a long way from then also. But just got it now for fitment purpose. Since im swapping in a different set of seats. An for the prices they are going for its kinda hard to not pass up.
  4. ULTM8Z
    ULTM8Z Veteran Member
    9,320
    457
    May 19, 2000
    Los Angeles
    Looks like you're planning to use the late model shifter assy? If so, I'm curious how that's going to work out...
  5. KJZ28
    KJZ28 Veteran Member Lifetime Gold Member
    3,134
    Sep 26, 2004
    Brewsterico, New Fail
    That center console looks great in 1st, 2nd, and obviously 5th :) I wonder if it looks good in 3rd and 4th?
  6. Revin
    555
    92
    Aug 31, 2016
    Round Rock , TEXAS
    Not "planning" on using it. Will "try" to fit a Mega shifter in spot.;)
  7. CAMeeks
    CAMeeks Veteran Member
    699
    42
    Jan 5, 2014
    Deer Park, TX
    I have the big T56. The Magnum. The shift stick that came with it is a 10" and I believe it will be like a rat rod if I use that one.
  8. Wayne Holcomb
    Wayne Holcomb New Member
    Jan 26, 2017
    How do you think the automatic shifter would fit ?
  9. Revin
    555
    92
    Aug 31, 2016
    Round Rock , TEXAS
    Time will tell. Just make brackets if needed. I am too far from there to say.
  10. CaliCamaro75
    439
    31
    Sep 6, 2015
    Winchester,CA
    You may be able to make the A/T shifter bezel work from the 5th gen console. I just picked one up recently. An just recently installed it with my 300zx seats.
