6.0 truck motor/auto trans/ecm and wiring
Discussion in 'High Tech Retrofits' started by John Wright, Jan 19, 2006.
  1. John Wright
    14,700
    212
    Aug 9, 2002
    Rustburg, Va
    opinions wanted:
    Would it be worth the trouble to go through putting this combo in a early 2gen or should I wait it out and find the money to go with the GTO/Camaro/Corvette or similar motor combo?
  2. camrs73
    camrs73 Veteran Member Lifetime Gold Member
    1,923
    Jan 3, 2000
    ct
    effort wise, it'd be the same as swapping in an ls-1 but you get the extra displacement and the option of iron or aluminum block i believe. a plus for the iron block is that it'll handle more boost then the aluminum. i've said it many times, i love the GEN 3 motors after driving the 5.3 in my truck. Bone stock this thing moves. i could only imagine what a hopped up 6.0 must be like.
  3. TRQJNKY
    TRQJNKY Veteran Member
    2,448
    Mar 27, 2004
    omaha, nebraska
    Only thing Id use is the block.. not the truck motor ... those truck intakes are sweet....
  4. John Wright
    14,700
    212
    Aug 9, 2002
    Rustburg, Va
    Cam, that was the reason I was asking. The 6.0 in my 2004 4wd crewcab jerks that ole buggy around pretty good and it weighs in at over 6,000#s.
  5. camrs73
    1,923
    Jan 3, 2000
    ct
  6. jakeshoe
    8,881
    21
    Dec 8, 2000
    Republic of Texas
    The 6.0 is the way to go IMO...
    Get a 6.0 from a 3/4 ton truck with the 4L80E, and do a cam swap, headers, tune it, and put a converter in between it and the 4L80....
    I'm using a 5.3/4L80 in a '55 Chevy.
  7. John Wright
    14,700
    212
    Aug 9, 2002
    Rustburg, Va
    I've been looking at wreck/salvage trucks:) They seem to be a bit cheaper than those other 6L packages.
  8. camrs73
    1,923
    Jan 3, 2000
    ct
  9. John Wright
    14,700
    212
    Aug 9, 2002
    Rustburg, Va
    Evilbay has lots of 5.3's out there in the salvage/wrecks...I saw an Avalanche that had been rolled......
  10. camrs73
    1,923
    Jan 3, 2000
    ct
    take a 5.3, swap heads, cam, intake, give it headers, you should be all set. i think the stock 5.3 heads have big chambers and tiny valves so coordinate everything in a 3200lb car and you should be all set :)
