6x9 speaker grills
Discussion in 'Car Audio, Electronics & Security' started by Chuck71RS, Mar 13, 2019.
  1. Chuck71RS
    1,440
    178
    Nov 24, 2012
    Houston, Texas
    On the underside of the grill opening is a very fine mesh material. What is it's purpose?
    I want to paint the exterior but the paint would cling to the material and degrade the sound.
  2. Green hornet
    Green hornet Veteran Member
    1,684
    278
    Oct 11, 2015
    North Bay, CA
    Hi Chuck ,
    Sorry I don’t have an answer to your question but I’m curious as to what speaker grill you are using. Do you have a photo? I ordered some grills the other day that I think are a little more period correct than the ugly a$$ things that are in the car now. Thanks
  3. tom3
    tom3 Veteran Member
    11,938
    330
    Aug 1, 1999
    ohio
    Probably to keep out bugs and dirt. Really can make a racket when bouncing around on the speaker cone. Might keep the sunlight off the cone somewhat too.
  4. Chuck71RS
    1,440
    178
    Nov 24, 2012
    Houston, Texas
    Got some inexpensive ones from Amazon.
    https://www.amazon.com/Magnadyne-sp...ocphy=1026481&hvtargid=pla-350611466073&psc=1
    The fine mesh material on the back
    *** keeps junk from getting on the hardware.
    *** Affects the lighting to hide the hardware. I could this masking after I took the material off of one and placed the other next to it. Found replacement material pretty close to what the grills will be painted.
