70 camaro is this a true non factory built camaro?
Discussion in '1970 - 1973 Specific' started by knightmoose, Apr 17, 2019.
  1. knightmoose
    knightmoose Veteran Member
    135
    Jul 24, 2010
    Phoenix Luke AFB
    68 adjacent only has factory heat & de-ice yet looks eerily similar as far as set up in the 70 --
  2. 74BIBELOT
    74BIBELOT Veteran Member
    865
    53
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    What about radiator support/ big-small opening, radiator itself hd or normal and ac condenser?
    hubedobeedo likes this.
  3. Smokey15
    Smokey15 Veteran Member
    3,130
    1,268
    Aug 13, 2017
    Caledonia, MI
    Heater hose routing looks like it was for a big block Camaro.
  4. 70 SS/L78
    2,750
    105
    May 5, 2005
    Rockford, MN
    Big block 2nd gens used same heater core as small block Camaro's, only 1st gen Camaro's were different.
    Dave in post #10 summed it up pretty well... Your car is or was an Air conditioned car at one time but it's been pretty much bastardized.
  5. knightmoose
    135
    Jul 24, 2010
    Phoenix Luke AFB
    i agree with you and dave as stated this car was in deed a factory ac car 20190423_133041.jpg 20190423_133048.jpg 20190423_172906.jpg
  6. knightmoose
    135
    Jul 24, 2010
    Phoenix Luke AFB
    only thing is now that i have it disconnected and i cut many of the rubber hoses form the back and disconnected what fills the void ? I mean i took the lower steering column cover off and then the ac module unscrews off the back on the left side that will leave a huge void an empty space where the module is at now ?
  7. Rich Schmidt
    Rich Schmidt Veteran Member
    4,278
    38
    Mar 27, 2010
    Denville NJ
    Your car had factory a/c,someone just ripped the suitcase out from under the hood. You need the kit for an a/c car.
  8. Rich Schmidt
    4,278
    38
    Mar 27, 2010
    Denville NJ
    Actually L-78 couldn't get air in 1970 either and 1971 and 72 Z's couldn't get air either.
