70 Camaro vinyl top best place to purchase
Discussion in 'Body Restoration' started by 70L78, Sep 18, 2019.
  1. 70L78
    70L78 New Member
    25
    Jan 6, 2004
    Ma
    Looking to put the black vinyl top back on my 70 and was wondering if anyone can suggest where to buy the best quality top. May also need moldings if I can't find my originals. Thanks
  2. 74Z28GC3
    74Z28GC3 Veteran Member
    1,667
    40
    Sep 1, 2000
    North Pole, Alaska
  3. 70L78
    70L78 New Member
    25
    Jan 6, 2004
    Ma
    Thank you for the reply. I'll call him and hopefully he can point me in the right direction and check for the moldings.
    74Z28GC3 likes this.
  4. CamarosRus
    CamarosRus Veteran Member
    8,479
    139
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Jon Haislip (Maryland / L78) told me once but I now forget....
    Do you homework to get correct Vinyl, Correct Seams.........
  5. Chuck71RS
    1,393
    169
    Nov 24, 2012
    Houston, Texas
    The factory vinyl on mine was a separate piece on both A-pillars with the larger piece tucked under. This seam provides an entry for water to get under. I did not realize this when the 1986 replacement was installed
  6. xten
    xten Veteran Member
    2,711
    1,483
    Sep 24, 2014
    Pittsburgh, Pa.
    Are you installing this yourself, or are you having a trim shop do it?
  7. 70L78
    70L78 New Member
    25
    Jan 6, 2004
    Ma
    I'm having a local trim shop do it, but I am supplying the material.
