'70 Factory U-Joint?
Discussion in 'Original Drivetrain Topic' started by Mulsanne Blue, Jun 19, 2009.
  1. FLH59
    FLH59 Member
    37
    Aug 18, 2008
    Here's a question ....
    What year did the factory start using the epoxy to hold in the U-joint caps? Also, was the epoxy used across the board or did some models or driveline configurations use clips?
    Just curious?
  2. FLH59
    FLH59 Member
    37
    Aug 18, 2008
    Anybody???
  3. ronzz572
    1,933
    55
    Feb 8, 2007
    imperial pa
    I had a late build 1972 olds cutlass remember it had the epoxy u joints in it.
  4. flowjoe
    7,957
    24
    Feb 7, 2006
    SoCal
    I've seen more Pontiacs done that way (with the plastic/epoxy retainer)- my '69 GTO for one, and two '69 Firebirds. A friend has seen a number of Pontiacs from the late '60s done that way (I consulted with him when I ran into my first one)
  5. TommyRS70
    TommyRS70 Veteran Member
    1,013
    48
    Jan 31, 2004
    KY
    0105191354a.jpg 0105191354b.jpg Here's a few pics of a NOS 3955571 u-joint with bowtie. No grease zerk.
  6. 70lt1z28
    2,930
    483
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I don't think 12 bolts ever had plastic injected to hold the bearing caps. The caps need grooves to make it work.
