70 Z Dual Snorkel Air Cleaner Day Two Modificantion
Discussion in 'High Performance Modifications' started by clm69z28, Sep 13, 2014.
  1. clm69z28
    clm69z28 Veteran Member
    146
    Oct 29, 2011
    encinitas ca
    70 Z Dual Snorkel Air Cleaner Day Two Modification
    Has anybody previously seen this modification to the stock Z air cleaner? I have seen one other air cleaner that was modified the same way, but that's it. The quality and the accuracy of the holes suggests that it was stamped- not drilled-which could have been done professionally, but that is only a guess on my part. Anybody have any clue? Thanks in advance for the feedback.
    Admin-I don't know if this is in the right sub forum, so if it should be somewhere else, please move it.
  2. CorkyE
    10,531
    546
    Punched or drilled, professional or shade tree, someone just made a lot of holes in a good air cleaner housing.
  3. Damon
    Damon Veteran Member
    12,939
    21
    Nov 16, 2000
    Philly area
    Wow, that's.... more on the "functional" end of the spectrum than it is on the "beautiful" end, isn't it?
  4. Mike-78 Z-28
    Mike-78 Z-28 Veteran Member
    1,909
    Mar 4, 2003
    ElDorado Arkansas
    Back in the day people used to do that all the time.
  5. roeville
    roeville Veteran Member
    1,259
    103
    Oct 9, 2000
    SF East Bay CA
    We used to just flip the lid upside down.
  6. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    It would be easier to buy a new Moroso air cleaner.
  7. ORANGE77
    ORANGE77 Veteran Member
    776
    Jan 17, 2002
    TRAFFORD, PA.
    My thoughts too, why? :rolleyes:
  8. rtanner
    rtanner Veteran Member
    177
    May 29, 2010
    fairfeild texas
    gm tsb back in 69-70 had em doing same to aircleaner on my moms 69 caprice w 327, only drilled holes in back though
  9. CamarosRus
    CamarosRus Veteran Member
    8,485
    140
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Looking to buy Original 70/71 Base (with bottom 90 degree tube intact)
    or Base with assy line Chrome Lid.
  10. COPO
    18,385
    1,040
    Get yourself an open element air cleaner and be done with it. That looks sketchy and redneck.
