70 Z28 engine frame mounts
Discussion in 'Swap Meet Section' started by 70RSZ28hugger, Dec 4, 2019.
  1. 70RSZ28hugger
    70RSZ28hugger Member
    77
    Nov 30, 2006
    San francisco bay area
    WIll the big block engine frame mounts work ? even though it might sit back further.?
    Im in the market for true Z28 ones.
  2. badazz81z28
    16,991
    522
    Las Vegas, NV
    It don’t recall it affecting engine location fore or aft. Just how high or low it sits.
  3. giggity
    giggity Veteran Member
    956
    103
    Mar 18, 2013
    Pearland, texas
    Not sure about the Z28 mounts, but when i put my big block in, I bought big block mounts and it rubbed on the power steering pulley, crank pulley, and headers hit. I put old 307 mounts back on and everything fit great. stock 307 left, big block right
  4. l16pilot
    1,847
    138
    Dec 13, 2004
    Hurlock, MD, USA
    For clarification....the BBC frame mounts are shorter, but that does not relocate the engine for or aft or vertically compared to the SBC mounts. Using the correct corresponding engine mounts, if you measure the from the mounting surface of the frame mounts to the mounting surface of the engine mounts , they are virtually the same. In 1970 and 71, the Z28 used the same frame mounts as the SS396, (BBC).
