70 Z28 Spoiler & Fender Emblems
Discussion in 'Body Restoration' started by 7dcamaro, Mar 23, 2019.
  1. 7dcamaro
    7dcamaro Veteran Member
    367
    Apr 10, 2012
    Warner Robins, GA
    Are the factory 70 Z28 spoiler and fender emblems the same size?
    I ask because I am about to buy these emblems. Classic Headquarters has the fender emblems with 3M double sided tape which is what I want so I don't have to drill holes. But they don't have the spoiler emblem at all. If they're the same size I'll just buy three of the fender emblems and use one on the spoiler...it's the 3 piece tall spoiler btw.
  2. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,242
    46
    Jan 1, 2005
    Schererville,In.46375
    Completed different.... your only option for the rear spoiler is to get the foil type emblem for the spoiler.
  3. bodymanbill
    bodymanbill Veteran Member
    1,306
    666
    Feb 1, 2007
    South Park Pa
    image.jpg I didn't want to drill my spoiler either . I bought the one with the studs and cut them off. The only problem is its hollow inside not solid like the fender emblems, I filled mine with epoxy than 2 faced tape it. It definitely was not easy to do, not sure if id do it again but it worked.
  4. 7dcamaro
    367
    Apr 10, 2012
    Warner Robins, GA
    What's different about the one on the spoiler?
  5. Ricks72Z28
    1,242
    46
    Jan 1, 2005
    The short spoiler emblem has studs, the tall spoiler uses the foil decal.
  6. JT71SS
    JT71SS Veteran Member
    500
    Jan 26, 2003
    McConnelsville Ohio USA
    70 and 71 tall 3 piece rear spoiler was a actual emblem. 72 and 73 used to foil decal
  7. 7dcamaro
    367
    Apr 10, 2012
    Warner Robins, GA
    So is the aftermarket one available for the spoiler correct for the 3 piece spoiler or the one piece spoiler?....or both? No where that you can order it from states which spoiler it is for.
  8. COPO
    17,882
    754
  9. 7dcamaro
    367
    Apr 10, 2012
    Warner Robins, GA
    Thanks for link. Am I safe in assuming that that same emblem is correct for both the one and 3 piece spoiler?
  10. badazz81z28
    16,923
    502
    Las Vegas, NV
    2F282419-B176-42DD-875C-1569DA7D7418.png I also cut off the studs and used 3m double sides tape. I have since upgraded.
