700 r4
Discussion in 'High Tech Retrofits' started by shoot1122, Aug 5, 2006.
  1. shoot1122
    shoot1122 New Member
    9
    Aug 5, 2006
    Does anyone know if the stock shifter will work with the 700 r4 transmission. My 74 Z28 now has ZZ430 replica and a turbo 350 tranny with 3.73 gears. I was concerned that the stock shifter would not work right. Let me know.
  2. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    They make a kit that you use with your horseshoe style shifter that has all of the detents for the 700R4 and it comes with a new gear selector plate with all the gears shown on it.(PRND321)
  3. shoot1122
    9
    Aug 5, 2006
    Thanks John for the info but I have the rachet style shifter. Do they make a kit for it also?
  4. rchydzik
    840
    24
    Nov 13, 1999
    Colbert, WA USA
  5. shoot1122
    9
    Aug 5, 2006
    Thanks Rchydzik, It looks good to me.
  6. Knuckle Dragger
    14,970
    1,428
    Nov 2, 2002
    Waddell AZ
    You can deal with shiftworks directly and save some money. They are exceptional people to deal with.
    http://www.shiftworks.com/
  7. Twisted_Metal
    27,154
    1,046
    I have one of the Shiftworks kits in my 80 Camaro for a 200-4R. This is the same shift detent pattern as the 700R4 and it works real good. You get a different cable bracket for the tranny too.
    My only complaint was the indicator lettering. Mine is an 80 and the indicator letters are on the shift plate. Yours are on the dash so I don't know what they supply for you for the indicator letters.
  8. Doug Jaynes
    Doug Jaynes Veteran Member
    1,577
    Jun 2, 2000
    Michigan
    the stock shifter will work. it just wont pull it all the way down to manual first gear but drive neutral ,park and rev line up at the detents. it did on mine anyway
    dj
  9. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    ^^ me too. 1>2 shift is at 6000 wot anyway.
