700r issues trani cable
Discussion in 'Transmission & Driveline Topics' started by johnnycamaroz, Oct 28, 2014.
  1. johnnycamaroz
    johnnycamaroz Member
    55
    Jul 22, 2014
    tucson,az
    Hey Guys,
    I just bought a 74 and somebody put in a 700r but still has stock shifter and cable.
    Needless to say you cannot put it in drive 2 or drive 1 it gets jammed and will not return.
    Is there a bracket or cable/bracket I need or even a new shifter??? to make it work correctly,
    This is my first700R conversion car.
    Any insight would be appreciated
    Johnny.
    also 1-2 shift is sloppy I heard the detent cable is line pressure and hard to get correctly adjusted. Oh boy sounds like im gonna go back to a turbo 400 ?
  2. CorkyE
    10,532
    546
  3. oledave60
    oledave60 Veteran Member
    804
    Jan 28, 2009
    E. Texas
    I am just finishing up a 350 to 2004r swap in my 73 and had the same problem with the shift cable. Got the one from shiftworks and it solved the problem, but I thought it was overpriced.
    Don't know what kind of carb you have, but the placement of the TV cable on the carb is very critical. I first had it attached in the back hole and had very late, hard 1/2 shifts. Moved it forward to next hole and now have very smooth shifts. There is a lot of good info on how to get everything adjusted, just do a search.
  4. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    A B&M Mega Shifter is what I'm using with my 700r4, its a 4 speed shifter. It works an haven't had any problems with it but its not real smooth either, an the gear indicator is worthless. But other than that I really like the 700r4. It took some time to get it set up just right but it shifts great an I love the overdrive. For a street cruiser / red light to red light racer its great. I'd only consister a TH400 for all out drag racing. You probably need a different cable for a stock shifter & you might have to take the pan off so you can tell if your getting a full pull from the cable then readjust the cable up by the engine. And you should have the correct bracket for the Carb your using if you don't have one. The cable adjustment is real important.
  5. johnnycamaroz
    55
    Jul 22, 2014
    tucson,az
    Thanks Guys I have a carter on it with plenty Adjustment to move the bracket forward or back but cannot seem to get the right.
    besides the cable is there any other adjustment I can make.
    also there is a wire hanging on the passenger side of the tranny?
    is that the lock up wire?
  6. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,795
    103
    Aug 18, 2003
    On Wisconsin!
  7. TexasT
    TexasT Member
    51
    Aug 4, 2007
    Texas
    Read over tvmadeez.com
    You might need a different spring in the tv valve. Are you using a gauge to set the tv cable? Pressure should jump when you have the cable disconnected and the engine idling and you pull the cable by hand.
  8. bygblok
    bygblok Veteran Member
    769
    Nov 28, 2010
    Pensacola Florida
    I've got a factory-type horseshoe shifter in my 70 with the 700r4 and it works fine. Has the shifter from bowtie overdrives with the extra gate for the overdrive gear. I might be swapping it our for something more "pro-touring" soon though. The TV cable is a pita to me but mine works well. I have a FAST efi system that uses the same basic lever swing that a 4150 holley uses. I got the cable static adjustment right and from there it was just a little fine tuning. Just don't let it get loose......it destroys parts then(clutches etc) My cable came off and I just about burnt the trans up before I caught what happened. It still lives though!!
  9. red78z
    red78z Veteran Member
    2,353
    Sep 12, 2009
    pottsville,pa.
    i have a b&m quicksilver, im looking into doing the od swap , what do i need for the shifter to make it accept the od?
  10. green 1977
    3,795
    103
    Aug 18, 2003
    On Wisconsin!
