71 AC hose routing question
Discussion in '1970 - 1973 Specific' started by DrPepper, Sep 1, 2019.
  1. DrPepper
    DrPepper Veteran Member
    194
    39
    Aug 29, 2017
    Central VA
    Can anyone tell, or show, me how the AC hose is routed from the bottom of the condenser to the evaporator? I'm not sure how to route the hose either thru the core support, or does the hose go under the core support??
  2. 70 Proof
    70 Proof Veteran Member
    550
    58
    Sep 28, 2014
    Southern Utah
    It doesn't go under or thru the core support. On my 70 It runs along the fender and behind the battery up to the condenser.
    On your computer search 1971 Camaro AC hose routing and see what comes up.
  3. Budz
    3,113
    123
    Mar 17, 2002
    Ashburn, Va USA
  4. DrPepper
    194
    39
    Aug 29, 2017
    Central VA
    Thanks, that helps a lot.
