71 camaro windshield wipers
Discussion in 'Troubleshooting & Diagnosis' started by rhardwick, Nov 26, 2007.
  1. rhardwick
    rhardwick New Member
    15
    Mar 12, 2007
    Odessa,Florida
    I bought windshield wiper arms from npd for my 71 camaro they said they fit 67-72 camaro,I installed them with new 16" wiper blades evrything worked great until I went to close the hood it hits the wiper arms.Any suggestions ?.The npd part# is
    c-10147-1
    I found wiper arms from a 76 camaro on ebay does anyone know if they will work?
    Thanx in advance for any help
    Rick
  2. April81Z28
    April81Z28 Moderator Lifetime Gold Member
    4,423
    Jun 15, 2004
    Eldersburg, MD, USA
    Hopefully some one more knowledgable will chime in.
    It sounds like maybe you have the hideaway wipers and got the standard arms instead of the hideaway ones.
  3. Jazn_84
    Jazn_84 Veteran Member Gold Member
    502
    Sep 21, 2006
    Fulton, IL
    That would be my guess too. Do you know if you have hideaway wipers? If you got arms that would fit 67-72 they won't work on the hideaway system, hideaway parts would be 70-73 specific. Maybe all the way to 81, I am not sure how long they made the hideaways. There is a way to tell by looking at the wiper motor if you aren't sure. I think the round motor is hideaway and the square motor is standard, but don't quote me on that.
  4. rhardwick
    15
    Mar 12, 2007
    Odessa,Florida
    I Changed The Wipers To A Cheaper Brand They Dont Stand As Tall On The Windshield,i Have Minimum Clearance Now.i Still Dont Think I Have The Right Setup The W/s Wiper Motor Is The Square Type.
  5. Eaglefixer
    Eaglefixer Veteran Member Lifetime Gold Member
    1,574
    Feb 25, 2002
    Warner Robins, Ga
    I have the same problem so i'm trying to find the the right type. I believe these are the ones I or we need. I'm going to call the tech line tomorrow and make sure. http://www.yearone.com/pco/8_0907/0127z.asp X6
  6. bfendick
    bfendick Veteran Member
    140
    Dec 3, 2006
    Vernon, BC
    I think that its the blades, not so much the arms . Original blades are really flat and, as they are metal, have wiper blade refills that should be changed instead of the complete blade. Aftermarket blades stick up to high and caqn contact the hood. Hope this helps, Bob
  7. rhardwick
    15
    Mar 12, 2007
    Odessa,Florida
    thanx guys.I thank you are right about the blades the cheaper ones I bought were not as tall, I also went to the 18" blade seems to work fine.Eaglefixer I used the straight arms that were used on 67-69, npd were sold out of the blades so I bought them from autozone.
  8. 1974TypeLT
    1974TypeLT Veteran Member
    688
    Mar 19, 1999
    NW, FL USA
    Try the Trico Exact Fit. They are the only ones that will clear my hood cowl.
  9. 70rat
    70rat Veteran Member
    1,861
    Mar 23, 2003
    Reno,NV USA
    Wiper arms from 67-69 Camaros are different than 70-76 Camaros.18" wiper blades are used on the hidden wipers from 70-81.
  10. Eaglefixer
    1,574
    Feb 25, 2002
    Warner Robins, Ga
