71 pro touring/resto mod project
Discussion in 'Project Progress' started by Seventy1ProTour, Nov 22, 2017.
  1. Da-bigguy
    3,953
    197
    Jan 19, 2010
    Cypress, TX
    It is looking fantastic!! Looking forward to seeing more pics!
  2. Zulu28
    Zulu28 Veteran Member
    285
    21
    Dec 19, 2013
    Vancouver, BC
    I'm going the same route as you, are you using a stock width rear end housing?
  3. Seventy1ProTour
    Seventy1ProTour Member
    67
    14
    Oct 18, 2017
    Huntersville NC
    Update. Brembo brakes are good, 1.125" bore master, disc disc gm proportioning valve.
    Sold the xxr wheels and got 18x8.5 and 18x10.5 c7 z51 wheels with nitto INVOs. 265/35 and 295/35.
    Jon balch and Zulu28 like this.
  4. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    Added DandZcustoms splitter above and also a 1" block for the rear. ^^^
  5. Turbo70Camaro
    2,146
    117
    Jan 7, 2005
    so cal
    Dude that looks so badass great job...................
    How much for the front spoiler and splitter??
  6. Jon balch
    Jon balch Veteran Member Gold Member
    233
    67
    Mar 29, 2017
    Upstate NY
    $900
  7. dave@ztech
    3,426
    712
    Mar 27, 2016
    NY
    Yes it's the freight that a killer on the front splitter/spoiler , and then you have to massage it to make it fit nice, figure another 8 hours, however it looks great when done!!
  8. Seventy1ProTour
    67
    14
    Oct 18, 2017
    Huntersville NC
    It was $700+shipping. I paid $185 to NC. I think I was able to get it on the car in about 2-3 hr's after thinking it over...needed persuasion.
  9. Zulu28
    285
    21
    Dec 19, 2013
    Vancouver, BC
    Looks great, I've been looking into Corvette / aftermarket wheels for my project as well, a couple of questions, did you have to alter the hub bore size to fit the stock spindles? I've played a little with an aftermarket wheel and I found that the hub bore would have to be machined, the other issue is if you do that then the center cap won't fit, another issue I found is I found that the spindle protrudes through the hub bore, did you have to use any wheel adapters/spacers?
